When I tried to use "ok" to access stations on my favorite list, all the response I got was an immediate "getlist timeout" I tried restarting and going back to initial settings (wiping out my favorite list) after that I cannot access shoutcast, same "getlist timeout". I tried accessing world stations, and have had some success in placing those selections on my new favorite list, but its difficult to duplicate my old preferences since there is scant genre info on world stations. also for a long time I've had trouble with selections on my favorite list (that previously worked) stop working and only respond with an "error message 8" the only way around it was to return to shoutcast and reselect the site for a favorite.
  • 2 more comments
  • virgilhollis Apr 03, 2011
    I'm not accessing this internet radio through a PC, rather I am using a Sabre Internet Micro System, which operates stand-alone independently of any computer connection, so I don't have any way of modifying the database on the shoutcast, or world stations segments, other than the controls on the front of the unit, or on the remote control. It is connected to a wireless router that is attached to high-speed internet service coming from my cable TV provider, Mediacom. (there was an instruction manual provided w/the unit but scant info on error msgs or failures in it. If there is a more complete instruction book (preferably with easier to understand directions and fewer obscure or obtuse acronyms, I would be interested in obtaining a copy.
    This is a Sabre Internet Radio/MP3 Encoding Micro System (about 8"w,8"d,7"h, with 2 external speakers, a small display screen, and a CD slot in front, most touch function controls are on the front and even more controls are on the separate remote keypad. On the bottom, as well as the instruction booklet is "Model # DIR 100 BKA, and date code: 09/2007. Logos on front include: Wifi Internet Radio, Direct Encoding, Grace Note, MP3, Real. This unit has many capabilities, many of which are beyond my need or comprehension, the only thing I've done is select a list of favorite radio stations, set my favorite local FM stations, and tried playing a music CD (but I have other CD players) The manual has 67 pages explaining many of the functions, often using terms and Acronyms I don't understand. My Wifi signal is unencrypted (so my neighbors might be spongind off it, as well as I can detect other Wifi signals in my neighborhood, but of weaker strengths. Since I'm able to access the "World Stations" but not the "SHOUTCast", I don't think the Wifi signal is a problem. (I have another smaller Internet Radio, but it doesn't have Shoutcast, only world radio tuning capability, and it works OK.
  • virgilhollis Apr 04, 2011
    I hope you can find something I can try to do, maybe these internet radios weren't designed for computer dummies like me. I though it would be an easier way to listen without figuring out or tying up the computer. I'll be waiting for your suggestions. Thanks.
  • virgilhollis Apr 07, 2011
    Here's all the info on my router: CISCO Systems/Linksys, Wireless-G Broadband Router, Model WRT54G (2.4 GHZ, 54 MBPS) Serial Number CDFD1FCG1401.
    President:
  • 2,187 Answers
Hi there to help you better, can I get the model and manufacturer of your router and the software that you are using. With the new settings that you have or list that you have can you check if it works directly connected to the modem? This is to isolate if the router or something on your computer is causing this.
Posted on Apr 04, 2011
  • 415 Answers
From what I gather Saber uses Penbex hardware and there's been a problem with it and shoutcast http://penbex.wordpress.com/2011/03/17/new-firmwares/ However they are fixing the problem with a new update and it should be available soon .
If you scroll down the page here http://penbex.wordpress.com/ you'll note that saber is on the list.
but that was for an older upgrade which you may already have. The shoutcast update is a new one
just posted on March 17th. So hopefully it will be available soon. The latest notice about the new update was posted March 24th stating they are working on it now.
Apparently you're not the only one who uses and likes shoutcast but has been unable to access it! I would have thought to look at your network connection but since you can get world radio that seems to be setup ok. I know this doesn't help you much at the moment but given there's been other complaints and that they are addressing the problem with a new update it's probably better to wait for the update then try getting a glitchy connection to work again only to have the same thing occurr again.
If I can find more that will help you I'll post it. Sorry I couldn't give you an immediate fix..
Posted on Apr 03, 2011
  • mszona Apr 03, 2011
    I forgot to mention that "time outs" have to do with an attempted connection that 'times out', takes too long to get a response which is the error you were getting. You can get that on a website too, or another type of server when it is either overloaded with signals trying to connect at the same time or when there's a problem on the server end ie it's down etc.
    If you get time outs on everything you try to conect to then it can indicate you don't have a net connection. However when you can get on one place but not another then it's a different problem, either on the other end, not your machine, or a problem with the network set up such as needing to open a port. But in this case you have a radio that is made to connect directly to radio where it could get world radio but not shoutcast. So we know you do have a connection.
  • 2,427 Answers
Hey,, sounds like there is a problem with your shoutcast profile,
your list is actually stored in a database, the reeor your getting is retrival for that database.
you can tray another browers, like modzilla firefox or google crome here are the links
GOOGLE CHROME
FIREFOX
but I strongly believe the problem isnt with you but a corrupted shoucast database. Unfortunately the only people that can help you with that is shoutcast themselves
http://www.shoutcastblog.com/
click that link, click contact us to the right of the page, fill out the form and tell them the problem your having, hopefully they can backup your profile and restore it without any loss of data from the corruption.
  • 2 more comments
  • Rishi Roshan Ali Apr 03, 2011
    whats the exact make and model you got let me see if i can find something you can use.
    Try to access your account from the pc and see if you still get the list time out error. !!! you ca also use the pc to back up yur list and then load it to another account.
    no the problem cannot be wifi or the internet connection it is eighter with the device or shoutcast itself and I'm thinking its the device. Jus havent figured i\out whats wrong with it yet..
    ok figured it out, the getlist function loads your favorites, basically your favorites is corrupted. Thats why the get list fails. In other words its damaged. (not the device your favorites list) thats why you can create a new list. See if there is a way to back up your list (newer models do) if not then sadly its gone!. Now we can try to reset the device, the easiest way to do this is to drain the power system dry. we do this by leaving it unplugged for a while and then plug it back on. A while meaning at least 2 hours.
Add stations to radio
try tuning to favorite station the push and hold down one of the favorite buttons for a few seconds, you should hear a beep or see the station number flash. if that doesn't work then there should be a button that has set on it. dial station, push set, push one of the favorite buttons and it should work.
Jan 26, 2013 | 2006 Hyundai Santa Fe
Tip
How to print favorites list in Internet Explorer 7
<p>Internet Explorer 7 has a gold star to help you remember your favorite sites. This icon of gold is on the left near the top of your browser. Just click on a Web page when you see interesting or useful, IE7 and stores the page title, URL and date of creation in your "favorites" folder. You can use a collection of favorite sites in time. Print your favorite IE7 copies of their role file at any time.<br /> <p> <br /> <p>Instructions<br /> <p>Save favorites<br /> <p>1. Open Internet Explorer and click on "File" to open the File menu.<br /> <p><br /> <p>2. Click "Import / Export" to the Import / Export window.<br /> <p><br /> <p>3. Click "Export to a file and click Next. Click on" Favorites "to select it.<br /> <p><br /> <p>4. Click Next. A list of folders appears. Click on the "favorites" folder to select it. This folder contains all add to your favorites.<br /> <p><br /> <p>5. Click the Browse button to the "favorites" file. In this window you can select where you want your list of favorites to save.<br /> <p><br /> <p>6. Look for the "Desktop" icon in the left pane; click the icon to select it.<br /> <p><br /> <p>7. Click Save and then click Export. Internet Explorer saves your bookmarks on the desktop in a file called "bookmarks.htm. Click" Finish ".<br />
on Jun 21, 2011 | Computers & Internet
How to move contacts and folders from old hotmail account to new hotmail account
Hotmail is a free online email service provided by MSN. Hotmail users can create contact lists in their email accounts, which allows them quick access to the contact information of their friends, families and co-workers. The contact lists can be easily changed, contacts can be added or deleted, information can be updated and certain contacts can be designated as favorites. Contact favorites are listed on the inbox menu for easy accessibility when composing emails or instant messaging.
Log into your Hotmail account using your Windows Live ID. This will open your Hotmail inbox. Click on "Contacts List" in the left-hand menu. Click "New" to add a contact to your list. Type in the contact's name, nickname, address, business information and phone number. You can also add other information, such as a person's birthday and personal notes. Click "Save." Your contact list will be immediately updated with the new contact's information. Delete a contact by checking the box next to his name. Click "Delete." Click "OK" to confirm that you wish to delete this contact. b> How to Change Hotmail Contact Information b> Log into your Hotmail account using your Windows Live ID. This will open your Hotmail inbox. Click on "Contacts List" in the left-hand menu. Check the box next to the contact whose information you wish to change. Click "Edit." Modify the contact information. Click "Save" to update the contact's listing. b> How to Create or Delete Hotmail Contact Favorites b> Log into your Hotmail account using your Windows Live ID. This will open your Hotmail inbox. Click on "Contacts List" in the left-hand menu. Check the box next to the contact that you would like to make a favorite. Click "Categories" from the top toolbar. Pick "Favorites" from the drop-down menu. The contact has now been added to the Hotmail favorites list. Delete a contact from the favorites list by clicking on "Favorites" in the left-hand menu. Click the highlighted star in the contact's information box. The contact is removed from the favorites list. Hope this helps.
b>
Jan 19, 2013 | Alpine Snow Hotmail & MSN Password...
I want to alphabetize my Imported from IE list
Right-click on the bottom of the list, under the last listed favorite, in the favorites list. In the pop out list click on Sort by Name.
Regards,
joecoolvette
Nov 13, 2012 | HP Mini 1000 Notebook
I just bought and updated a Garmin 1450 lmt. There is no edit button visible to edit my favorites. I wish to edit a favorite entry and following the instructions I touch "where to," then...
Press "where to", Press "favorites", Press "all favorites", his will list all favorite points stored in the unit. Scroll down til you find the point you want to edit. select it. It will show up on the map, and in the info bubble, it will say in blue "click for more", touch the blue words, and it will take you to a screen where you can select edit or delete.
Feb 23, 2011 | Garmin Nuvi 1450LMT
Pix 515 E allow few websites only.
Do the nslookup for the three websites and write an access list to permit the traffic only to the said website ip addresses
Eg.
1. go to dos prompt
2. type "nslookup"
3. type "www.rediff.com
Note : You will get the ip address of the websites
4. Create an object group for these websites
5. Add ip addresses of the websites
6. create an access-control list element to permit the traffic from your circle office to this object group for port tcp 80 and 443
You are done
Mar 09, 2009 | Cisco PIX 515E Firewall
Ploblems with dmz-outside (webpage). pix
Remove this line:
static (DMZ,INSIDE) 10.10.0.0 10.10.0.0 netmask 255.255.255.0
You don't need a translation going from a lower security level to a higher one. You will also need a nat line for the dmz so that pc's on the dmz will be translated outbound. The only connection that will work on the dmz is the webserver when he's sending traffic outbound with a source port of 80. Something like:
nat (DMZ) 101 10.10.0.0 255.255.255.0
Other than that, it looks like it should be working. You've got permission, a route, and a translation. Maybe "clear local-host 10.10.0.2" to get rid of any bad xlates and try again. Check debg level syslogs, run packet captures, "clear asp drop" then "show asp drop" after an attempt?
Feb 28, 2009 | Cisco PIX Firewall 506
Cisco asa5505 problem
You seem to have the last resort (o.o.o.o) set to VLAN1 which is set as an inside interface.
Is VLAN1 connected to the outside router or internet backbone?
If not, change the last resort to the outside Ethernet port.
Apr 16, 2008 | Cisco ASA 5500 Firewall
Computers & Internet Logo
158 people viewed this question
David Payne
David Payne
