Question about DCS RGS-486GD Gas Kitchen Range
Help in Replacing broiler igniter DCS RG-486GD
The igniter for the broiler has broke. I have removed the igniter from its holding bracket, but I don't see a way to disconnect the 2 electrical wires from the igniter without cutting the wires. I have not been able to find a new igniter locally so I can't see what is needed to install the new one. Thanks
Jeff,
You have to remove the back of the range; the wires plug into the gas valve that controls gas to the broiler.  They detach by pulling on the slip on connector.
Posted on Nov 26, 2008
If thre broiler stopped working is it always the broiler igniter that needs to be replaced. If so, how do you do it?
Sorry to read about your problem, I hope this helps you out.
80% of the time it is
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | DCS RGS-486GD Gas Kitchen Range
DCS gas oven and broiler that pulses
This sounds a lot like a defective pressure regulator. If you do not have one externally connected, then the internal regulator is faulty. If internal, it shouldn't be too difficult to DIY. Just make sure the pressure rating is the same as the one that has failed.
Mar 24, 2010 | New World G60m Gas Single Oven
I have a 15 year old DCS 4 burner gas stove and oven. Slide in. The broiler stopped working today. Is it the broiler or the fan? How much are parts?
the likely cause is the hotsurface igniter has failed. not exactly sure how to check the part but you can check it voltage is getting to the igniter. if you have voltage, it's probably the problem.
Mar 20, 2009 | DCS CMO-24-SS Convection/Microwave Oven
Gas burners are ticking
The ticking sound you hear is the electronic ignition which is located by each burner. When you turn a burner on the electronic ignition creates a spark which ignites the gas. Once the burner is ignited. turn the knob a bit further and the ticking will stop.
Feb 05, 2009 | DCS RGS-486GD Gas Kitchen Range
DCS stove igniters clicking
Actually Dave, when you turn on one burner, all of the igniters do fire. This is normal. Perhaps you never noticed it before. regards, Joe
Dec 19, 2008 | DCS RGS-486GD Gas Kitchen Range
12 inch door problem on model RDS-486GD dual fuel
you can take one of the screws to the hardwere store and get a self taping screw, or a screw one sides bigger. or you can use a ribbit, that will take care of it.
Dec 11, 2008 | DCS RDS-486GD Stainless Steel Dual Fuel...
Broiler won't ignight - 48" gas range
I had the same problem. I'm not a handyman. A repairman came out and had to replace the igniter. Had to order it from Europe, which took about 2 weeks. They get old and crack and don't work after a while, he said.
Oct 27, 2008 | DCS RGS-486GD Gas Kitchen Range
Broiler not working, Oven OK
We have a DCS RG-366 SS L, a 36" gas range and the igniter went out. You could smell gas and the igniter would glow red - but no fire across the broiler.
There is a place in Michigan called RepairClinic.com. We bought a replacement igniter from them and it works like a charm. It was $53 (we live close by and didn't have to have it shipped).
The item number (from the invoice) is 1191 and the box the igniter came in looks like it is manufactured by FSP, code 082005, and there is a larger number on the box that says 786324 IGNTR-OVEN.
Hope this helps.
Sep 13, 2008 | DCS RGS-305 Professional Gas Kitchen Range
RG 364 6D DCS gas range
Call 888-281-5698.  Parts ship from California, available next day.  I've had immediate, good, intelligent response.
Nov 29, 2007 | DCS RGS-486GD Gas Kitchen Range
Oven in DCS gas range doew not turn on
Well some of the older ones have a unit that is sorta like a pilot light which keeps you safe by not letting out gas before it ignites so as to not blow up. This macanism is probably bad. I use to replace them on Tappan ovens. They would last a couple of years and then would go out and to replace them then was about $80.00. Easy to do. They are usualy located inside the oven somewhere and look like a glass eye on one end with a small 1/4 inch gas line connecting to the other end.
Jul 30, 2007 | DCS RGS-486GD Gas Kitchen Range
DCS RGS-486GD Gas Kitchen Range Logo
895 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal DeAngelo
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
