Question about Directed 1900G GM Databus Interface Module
06 duramax with astroflex (directed ) remote start. lights flash,doors unlock,lock. won' t start though. all fuses good. need a manual and suggestions please thx
2 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: 04 Escalade w / Valet Starter, all works but door locks
Hello 7suds,
Well, I'd go back and tell them about the doorlock problem. I know that 2 years is a little late to start complaining, but it's most likely a really easy fix.
The most probably causes are that the power doorlock output was either not programmed, programmed incorrectly, or it's not connected or improperly connected to the vehicle servos. Have the installer check the programming, especially the doorlock pulse duration. It's also possible that the remote is simply not sending the doorlock signal. Could just be a bad button. Have them switch the doorlock function to the right "AUX" button temporarily and see if that works. But in any case, the system needs to be tested to find out exactly what is causing the doorlock failure.
Hope this helps.
Posted on Jul 16, 2009
Avital 3100 keyless entry remote sets off alarm when trying to unlock or lock doors with remote. Doors stay unlocked but alarm keeps sounding off and car wont start.
hi'
i think the wire that connects to the door trigger for the interior light
a negative or a positive one has been mixed up
if its neg change it to the positive one
if its positive change it for the negative one
25666027-extj4arg1t42xbh3l3byl5v2-3-0.jpg the purple or green wire
cheers
Apr 26, 2015 | 3100L 1way Security System
1997 850 volvo, when i manually open door with key, the car won't start and lights flash....so now only use the remote, Now remote won't work - had new battery in remote- suggestions on how to lock doors?
Try this trick, push the lock button once your in the car to unlock first then lock then unlock again, your kill switch is activated as anyone could unlock the door with a key, but to be linked together via bluetooth remote is exclusive and good practice if you choose to stop a thief
Aug 13, 2014 | 1997 Volvo 850
I got the Viper 5101 remote start installed in my 2007 Hyundai Sante Fe at best buy. The remote works for auto start, but will only lock and unlock the doors sometimes. It seems like if I unlock or lock...
I would take it back and tell them they need to fix it. it sounds like a wire for the lock/unlock may of fallen off or there is a problem with the remote stare module. wires tend to fall off if all the used were crimp connectors and didn't solder the wires together.
Jun 01, 2017 | Hyundai Santa Fe Cars & Trucks
Will not unlock doors. Battery is good and flashes all lights on transmitter and LED inside vehicle. Remote start will start up and shut down vehicle fine. Just does not lock or unlock doors. Locks work...
Have you changed the battery recently? My remote has a bad habot of slightly misaligning the cel switches if I don't close it exactly right. For my Chrysler van the sliding door switch is affected that way. All else works, though. I end up opening the remote again and ensuring it snaps shut all the way around with just one compression. If an edge doesn't close it's try again. The good news is it's virtually always the remote at issue and nothing expensive in the vehicle.
Jun 06, 2017 | 7900 RB 7900 2Way Color LCD Remote Start...
Remote door locks won't work
There is a flash for the body control module for this problem. You need to go to the dealership to get it performed though.
Mar 07, 2009 | 2005 Dodge Grand Caravan
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Program a remote key for 03 A6
I have an A4 and did this to re-program my key:
1. used the key to start the car...then turned it off
2. put the key in the driver door (door closed)
3. pressed the lock button on the key fob once
4. turned the key to lock the door.
This is basically the steps in the owners manual, but the car must be started with the key first, and the key must be in the door lock before pressing the lock button.
Dec 10, 2008 | 2003 Audi A6
Keyless entry keylob want lock or unlock doors or trunk.change battery and checked all fuses.
You need to program the remote. Get in to the car and LOCK all doors with the switch on drivers side door. Take the key and insert it into the ignition cylinder in and out 6-10 times, until the flashers/hazards flash on your dash board. Or just keep putting the key in and out (nice and easy now, not fast) until you see the lights on dash flash. After the lights flash, turn the key into ACC mode to make the whole dash light up.(do not start car) .With the key in ACC position, hit any button on remote, that will make the hazards flash again. Turn key off and unlock door with switch again. Open door.DONE.
Good luck.
Jul 15, 2008 | 2001 Nissan Altima
Directed 1900G GM Databus Interface Module Logo
Top Directed Computers & Internet Experts
David Payne
David Payne
Are you a Directed Computer and Internet Expert? Answer questions, earn points and help others
