Uttle@hotmail.comWhat setting on my Vizio tv do I use when connecting my pc
    Sergeant:
  • 378 Answers
RGB Computer or VGA.
Posted on Apr 03, 2011
Testimonial: "jus what I needed to know, TY"
I have a vizio L13e tv trying to connect to a universal remote need to set ip address please help
I think you may be looking for the remote IR device codes for Vizio TV for your universal remote. I have the following codes listed for Vizio on one of my universal remotes: 1009, 1030, 1346, 1413, 1414, 1415, 1459, or 1461. Set your remote's TV mode to each code to find the one that works on your TV.
Jan 12, 2015 | Vizio Televison & Video
I have an asus Eee PC Seashell series netbook and I'm trying to connect it to a vizio smarttv but it keeps showing "no signal" on the tv
Have you checked these?
1. Input settings in the TV,
2. Cycle the laptop output (laptop screen, external screen, both)
Mar 10, 2014 | ASUS Eee PC 1005PE (SeaShell) Netbook
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Sep 20, 2017 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Problem with Vizio SV421XVT
I am also having the same symptoms for my SV421XVT. TV works great except all HDMI ports are not receiving signal. Devices work through the AV Ports, and TV reception is fine. New Roku box is also not working through HDMI but works with AV. Wish I had a solution to this.
On a another forum for another TV it was suggested that boards need to be replaced. I hope I can get these boards for a reasonable cost.
Aug 16, 2012 | Vizio SV421XVT 42 in. LCD TV
I HAVE A VIZIO TV #VA26LHDTVIOT AND I WANT TO GET BLOCKBUSTER STREAMING. I WAS TOLD TO USE MENU SCREEN TO GET CONFIGURE AND OR SETTINGS. NEITHER OF THESE ARE THERE. CAN YOU HELP?
This is the official technical specifications of your tv
http://www.vizio.com/va26lhdtv10t.html#techspecs
As you can see there is no mention of a network capability , let alone streaming. Actually this tv doesn't have even USB ports so you can't even connect an memory stick and play a movie on it. So streaming is out of a question with this tv.
Sorry, you can't do it. Either get a better tv or use a pc connected to the internet for which the tv will be the monitor.
Sep 08, 2011 | Vizio VA26L 26 in. LCD HDTV
I have a vizio vf552xvt lcd led hdtv and i wood like some help with connecting my computer dell xps 8100
You can connect your computer in your television by using VGA connector cable or HDMI cable.Then set the TV into PC in by selecting at the menu setting.
Jul 04, 2011 | Vizio VF550M 55 in. LCD HDTV
The Netflix app on my vizio svt422xvt (one of the Vizios with VIA internet & wifi built-in) won't connect to Netflix. It directs me to the Netflix website for help, but Netflix help tells me to...
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
Aug 11, 2010 | Televison & Video
Extended my monitor to a Vizio 37" LCD TV Echoed Sound
You have an HDMI connection on a Thinkpad T20???
Per definition, HDMI is supposed to send video and audio data from the TV to the PC -so, yes, it should work.
I say "should", because I tried to hook up my PC that way and I went back to a VGA connection (and sent the sound to an old stereo), because the resolution was awful.
I rather think that the audio cable is the culprit here - if the connectors are not fitting perfectly, they can create a lot of distortion.
Also check your audio settings on the PC (updated driver, settings not on maximum volume, etc.)
If you want to try HDMI, there is no need to get the ultra expensive "Monster" cable. Look here for an example.
Feb 24, 2009 | IBM ThinkPad T20 2647 Notebook
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
