Question about ViewSonic VG700b 17" LCD Monitor
I have monitor view sonic(VE910b), suddenly monitor is stop working, monitor has solid green light, looks every thing ok, I am getting sound of shutdown and starting windows and I am getting perfectly display on my LCD TV but not getting display on monitor, pls help to fix it. Thanks
  • 11,361 Answers
It does the same when attched to another PC? Otherwise it may have bad caps prblem like the 17" version as shwon here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VE710B/
which is very common to LCD monitors that are more than 2 years old.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Apr 03, 2011
My view sonic monitor is getting power off suddenly, how to fix this problem
Check your lcd power for bulged capacitors & change them with the correct values; sure it will work fine
Jul 21, 2015 | ViewSonic VA1912w 19" LCD Monitor
VE910b - Veiw Sonic monitor, when i turn the computer on the monitor will flash for anywhere from 30 seconds to 10 minutes before it stops flashing and i can use it. When flashing it will go from black to...
The backlight inverter is failing or the power supply feeding it is not good.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Apr 18, 2010 | ViewSonic 19 VE910B 1280X1024 TFT LCD...
Have an old view sonic vx900 (~5yrs old). When you
Check the fuse on the inverter board and also verify it does have have 12vdc feeding the fuse. Worst case will be the lamps, power supply caps look OK?
Jan 18, 2010 | ViewSonic VX900 19" LCD Monitor
Green light blinking , no display ,,
look inside for bad caps, see example of failed Viewsonic monitors here: http://s807.photobucket.com/home/budm/allalbums
You should have 5v and 12v in the power supply sections.
Jan 17, 2010 | ViewSonic : 19" Graphics Series Flatpanel...
View Sonic VA720 monitor goes out after power goes
replace the logic board, not the power supply board. you can find logic board on ebay as low as $29...
Nov 15, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
My view sonic monitor does not work properly
sounds like the power supply inside of the monitor is going bad. did you replace the cable from tv to the wall?
Oct 16, 2009 | ViewSonic VX922 19" Monitor Flat Panel
I use this monitor mostly for computer and yesterday when I turned it on everything had a green tint to it
Make sure the connections are tight. Are you using DVI connections or Analog?
Also, make sure your video care is properly seated on the motherboard.
May 28, 2009 | ViewSonic VX922 19" Monitor Flat Panel
I have a ViewSonic VE910b 19" That the display stays black
What your both experiencing is a slow degradation of the inside light bulbs. Just like what happens to regular fluorescent bulbs, they slowly flicker out.
Best to buy a new monitor.
Take apart your old one, you'll find burnt out bullbs on the upper and lower chassis deep inside.
Apr 22, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Some green color patch in the middle of the screen
Looks like you have an LCD. I was guessing it may be magnetic related in which case I would recommend you degaussed your display using the degauss function but your monitor won't have it since it's not a CRT by the looks of it. I would recommend contacting your dealer or where you purchased the monitor at a retail store. Since it's only 8 months old, you may be able to return it under warranty. If your retail store doesn't let you do that, talk to View Sonic directly and see if you can RMA your product for returning to the manufacturer and receiving a new or repaired unit.
Check out Viewsonic's website for more information.
Mar 24, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Sound on the View Sonic Monitor
Yes, they are on the front of the screen. There should be a volume up and down button right on the front (usually to the left of the power). If there isn't a separate up and down, try the Menu or 1 and 2 buttons.
Aug 18, 2008 | ViewSonic 19.0" VG910B 1280X1024 TFT LCD...
ViewSonic VG700b 17" LCD Monitor Logo
120 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
