Question about Brother MFC 8220 All-In-One Laser Printer
Brother multifunction laser printer, model #8220 : can you use color ink cartridges with this model or black /white only?
  • 844 Answers
Welcome to FixYa!
The MFC 8220 is a Laser Printer. It uses Toner Cartridge. Product #TN540 or #TN570. It cannot use the regular ink cartridge.
Brother multifunction laser printer, model #8220 : - jas247_40.jpg
See full details in this link: http://www.brother-usa.com/MFC/modeldetail.aspx?PRODUCTID=MFC8220&tab=supp
Thank you for using Fixya. Jas247
Posted on Apr 03, 2011
  • 8 Answers
The MFC-8220 is black and white only.
This can be confirmed at http://www.brother-usa.com/MFC/modeldetail.aspx?PRODUCTID=MFC8220&tab=spec
Pro905 is out of color ink. can i print in black and white text only
The Lexmark Platinum Pro905 needs all four inks to have substantial ink for printing at all times in order to prevent damage to the printhead. This is why a user has to replace empty ink cartridges to continue printing. This includes color cartridges for black only jobs.
Nov 26, 2011 | Lexmark Platinum Pro905 multifunction...
Brother MFC-290c printer does not print black anymore. Test print page color ok but not black printing. What is the problem?
The problem is either:
* out of BLACK ink -- replace the ink-cartridge
* clogged ink-jets -- the ink is not spraying onto the paper, so run a few print-head-cleaning cycles
* dead electronics -- not triggering the jets to spray ink, so replace the printer
Feb 20, 2011 | Brother MFC-290C Multifunction Color...
Mfc 290, replaced ink cartridges and the black will not print only the colors. printer cleaned and no progress. any help?
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Nov 30, 2010 | Brother MFC-290C Multifunction Color...
New brother laser printer hl-2140 with new ink cartridge . All printed pages are covered with black ink. Slide the cleaner and even change cartidge, but same problem.
Please try to re align the print heads and service the carraige assembly of the printer ( Place where you slot in your cartridge). if it doesnt work then there is a leakage on the ink piping system.
Replace the Ink service station.
Sep 23, 2010 | Brother HL 2140 Laser Printer
What are the procedure to use only black ink using brother DCP-165c?
Description of Problem 100000016244
Can I print using only the black ink cartridge when any of the color cartridges are empty? Grayscale
Description of Solution 200000023550
To view information and instructions with graphics please go to the website listed below:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002400/000061/faq002461_001.html?reg=us&c=us&lang=en&prod=mfc6490cw_all
Jul 10, 2010 | Brother DCP 165C Compact Color Inkjet...
My printer will not print in black. It will use the other colors, but not black. When I try to print a black and white document, it prints in blue.
if u want to print selected document in black than open the document select print go to printer properties select grayscale printing
always print in black
go to printer properties than go to maintenance than go to ink cartridge setting select ink cartridge black only for balck and white printing only.
OR
CHANGE CARTRIDGE
Jun 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
Can i print black prints without refilling the color ink cartridges? my color cartridges are empty but the black is full. The printer wont let me print black and white files.
Not certain on that model of Brother but on mine I was able to get it to print by changing the settings in "Print Setup" If you change these so that it can only print in black and whiye, it won't look for the colour cartridge, like mine didn't
Jan 24, 2010 | Brother MFC-5440CN All-In-One InkJet...
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
I cannot print black when the color cartridges are empty. MOdel mfc665cw
Don't you see the logic? Brother wants you to spend money by buying color cartridges. And also, most printers are also using colors to make the prints darker.
Jan 09, 2010 | Brother Office Equipment & Supplies
I need to know if this printer, MFC-8660DN is a color printer. If so what cartridge do I buy. I can find nothing stating it is color.
This printer is a multifunction black and white laser printer. It takes the Brother TN580 cartridge. There are many sources for this cartridge, just google it.
Aug 05, 2008 | Brother Office Equipment & Supplies
Brother MFC 8220 All-In-One Laser Printer Logo
125 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
