Question about Vizio VS420LF1A TV
How do I change my screen size on my vizio - Vizio VS420LF1A TV
Vizio vw32l color changing blue to purple
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 02, 2017 | Vizio Televison & Video
My 50 vizio plasma tv works fine but all of a sudden 1/3 of the screen vertically has went black. Which board do I need to change to fix this. Thank you
Sustain board. If you wish to get some details; visit the site linked here. Pull up older posts.
May 31, 2017 | Vizio Televison & Video
I have one vizio e701i-a3 with black screen but with audio. I change the t con board and the main board. But the problem continue. I need help please
Sounds like display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 21, 2016 | Vizio E701i-A3
BLANK SCREEN VIZIO LED TV
Check and replace the T'Con board. It has damaged. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Vizio Televison & Video
42" Vizio. How do I change screen size?
Hi Beverly,
There will be a key 'P Size' or picture size on the remote control. Please use it to select the picture size of your choice.
Happy viewing.
Aug 10, 2015 | Televison & Video
Hello, pretty simple probably. How do I use the entire screen for the picture, I can hardly read the news scrolls that come at the bottom of the screen cuz of the 3 inches of black border all the way...
No.Some u can't changes the tv picture on the screen sizes,because depending the bandwith of ur tv are recieving.Most u can changes the tv on picture to wider screen or to fit the whole tv screen.U have the tv original remote wright?Yes.Look a button that said like Viewmode,Aspect Ratio,Picture sizes,Zoomming.Pushes one of these name buttons u will able to changes tv on screen pictures sizes.
Aug 23, 2011 | Vizio 42 in. LCD TV
Need to fit picture to size on screen. Some of the words are not within the screens ratio.
Use your remote and hit munu... then change your picture size until you can get the right size for your program.
Oct 08, 2010 | Vizio VX37L Television
Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Mar 14, 2010 | Vizio VW42LF 42 in. LCD HDTV
There is space above and below the picture. How
youmay have to change the aspect ratio either on your cable or satelite box. if thats not it it will be a button on your tv remote like aspect,picture size etc.
May 18, 2009 | Vizio L37 Television
Vizio VS420LF1A TV Logo
837 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
