Question about Hunter (25417) Ceiling Fan
I just bought hunter fan model 27477 with remote put it together will not work can you wire the fan without the remote using 14-3 wall switch mike
JayBlair
  • 328 Answers
SOURCE: hunter ceiling fan
Have you contacted Hunter? Have you turned off the wireless internet to see if fans work? You may have to try another internet brand or try moving to another part of the house.
Posted on Aug 13, 2007
SOURCE: Remote control ceiling fan
I am changing the remote in hunter fan an i got the wires mixed up coming from the fan what wire goes where?
Posted on Apr 12, 2008
KMusselmann
  • 247 Answers
SOURCE: Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Posted on Mar 17, 2009
SOURCE: need a hunter westside2 model #21621 instructions w/ pictures
Costco.com has an online manual for this fan. That is the same model number you are looking for.
Posted on Jun 13, 2009
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Posted on Aug 20, 2009
Install a hunter highland remote in a prewired house that has 2 lights on the same main switch
Prewired for ceiling fan (colors, installing, bedroom, lights ...
www.city-data.com > City-Data Forum > General Forums > House
Jan 29, 2009 - 10 posts - ‎3 authors
In my new house, there's 2 switches so I can do them separately. ... is there anything else I can do with that switch since the fan has a remote and I won't be using it much? TIA. .... Those same wires should be in that switch box.
Wiring on ceiling/fan light combo with remote and ... - Bob Vila
www.bobvila.com/.../82070-wiring-on-ceiling-fan-light-combo-with-re...
Oct 3, 2007 - I can have installed the fan/light (a Hampton Bay Veranda) without the ...My house wiring has a green ground and two black and two white wires. ... Fortunately I found a universal/all brand fan speed control wall switch made by Hunter. ... i havethe same problem . so you just did not used your remote?
Jan 19, 2016 | Hunter Dryers
How to eliminate receiver/transmitter in hunter 28425
Open the box at the bottom of the ceiling fan, where the switch is. You should find the receiver inside there. You'll find one white wire connected to it, and two black wires also connected to it. Remove the white wire completely or cap it off with a wire nut. Connect the two black wires to each other with a wire nut. Reassemble the ceiling fan. If the problem was the receiver, then the problem is now gone because the receiver is gone.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
Hunter fan remote bypass
This fan uses a "ballast" to run the fan. The ballast (part #272) probably contains wiring for multiple speeds. Here is a manual that discusses the wiring- http://www.hunterfan.com/SupportDocuments/OwnersManuals/42700.pdf.
To use a wall mounted fan dimmer, you need to identify the high speed wires and connect them to the dimmer switch. This method will bypass the other speed windings and is not as power efficient.
Jan 31, 2014 | Hunter 21617 Palermo Brushed Nickel...
Hunterfan com
If you have a remote then you can't use the dimmer switch on the wall. Put in an on/off switch.
Sep 20, 2013 | Hunter 52" Ceiling Fan With Light And...
I purchased a hunter universal remote and have a hunter fan with canopy I am trying to get it hooked up to. I have all wiring configured the way it shows on diagram and still nothing. From the box in...
If everything is wired correctly, disconnect power at the source, then reconnect power and experiment with every possible combination of wall switches and the remote until the fan works correctly. At that point, do not use the wall switches again, ever.
Apr 17, 2017 | Hunter 27187 Remote Control
Hunter fan model 21617 remote fan won't turn on light from wall switch
You mean only the light? and the fan is working? Have you checked the light bulb? If it's ok, then checked on the wall switch. If is also ok, then probably there's is something wrong with the wiring in the fan.. It's either a bad or loose connection
Jul 01, 2010 | Hunter Ceiling Fan Light Switch Control
Hunter 93886 fan
You may be drawing to much amperage for the switch to handle both fans. You may be underwired if it is an old house. you can hook wires together without switch in place and see if everything keeps working but don't hook them together with the power on. Also don't run very long as the wires could heat up. Run for about 5 minutes and turn power off and check heating of wires.
Jul 28, 2009 | Hunter 235 Fan
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Remote Chewed Up
i had similar problem with remote , went to home depot to buy a new fan and saw they had new remotes and receivers for the hunter fans , i bought the kit ( which had a remote and a receiver for a non remote ceiling fans) and was working again . salesman was very helpful .thanks.
Dec 30, 2008 | Hunter 52" Ceiling Fan With Light And...
Grande Lodge Fan
I have an existing ceiling fan with an add on remote control. Does anyone have a wireing digram or can tell me how to wire it up. The switch on the wall kills all the power coming to the fan. I have the color wires wired together(pink to pink , etc.) It is a hunter add on divise. Model # CP911OR
Aug 06, 2008 | Hunter 52" Ceiling Fan With Light And...
Hunter (25417) Ceiling Fan Logo
114 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
