Question about Amana AER5515QA Electric Kitchen Range
Heat element burnt out replaced with new, still will not heat
One of heating element burns out how can i replace it? amana brands cooking range
Posted on May 22, 2011
Original Heating element and replcement elements both burnt through at same isolator...just that lucky or another issue that causes that problem?
If the new element burnt through quickly then I would suggest replacing the insulator just to be sure before installing a new element.
Nov 05, 2015 | Dryers
The wire connecting to the heating element keeps melting/burning. Ive replaced it twice, each time it melted, how do i fix it?
What size wire? When you replaced the heating coil, what did you use? Was it OEM? What part number? Do you have an ohm meter?
Apr 11, 2014 | Dryers
Maytag Dryer MDE3706AYW has a burnt black wire, did the wire just have a bad day or do I need to replace the heating element and the wire?
All should be good. I think the element had run on due to a bad hi-limit thermostat that you said you replaced.
Oct 17, 2012 | Maytag MDE3706 Electric Dryer
Should the heating element on my oven be entirely red ? 80 % turns red right now.
it sounds like the heating element you bought is damaged or burnt out.
return it for an exchange
May 03, 2012 | Jenn-Air Ovens
The main burner (left front) only heats on half the circle.
Your referring to an electric range I'm assuming. In that case the heating element is only heating to a mid-point then stopping. This typically means the heating element is burnt or is partially burned out. The element is usually user replaceable and requires the old one be unpluggude and replaced with a new one. You'll need to get the element from the manufacturer.
Apr 21, 2010 | GE Cooktops
Fan runs no heat from element
IT SOUNDS LIKE THE ELEMENT HAS BURNT OUT , REMOVE THE BACK PANEL FROM THE INSIDE OF THE OVEN BUT FIRST MAKE SURE THE POWER IS OFF WHEN THE PANEL IS REMOVED DISSCONECT THE TWO WIRES FROM THE HEATING ELEMENT TAK IT TO A PLUMMERS SUPLY STORE FOR REPLACEMENT , REPLACE NEW ELEMENT AND YOUR OVEN SHOULD WORK FINE .
Nov 16, 2009 | Ovens
Not heating. cycle still runs but there's no heat.
SOUNDS LIKE THE HEATING ELEMENTS HAVE BURNT OUT , REPLACE WITH NEW ELEMENTS .
Nov 01, 2009 | GE Profile Harmony DPGT750EC Electric...
Kenmore electric dryer model#96260100
tim, check to see if your motor switch is stuck. it allows the other power leg to be sent to the heater. comes on when the motor starts turning and releases upon the stopping of the motor. other power leg comes through timer, hope this helps.
Aug 27, 2008 | Dryers
Amana AER5515QA Electric Kitchen Range Logo
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
