Question about Car Audio & Video
How many channels it has? Need wiring pinout.
  • 794 Answers
Hi sanjeev_gupt,
May I ask for the specific Brand and Model name so I can provide you the correct wiring diagram.
Thank you for using Fixya.
Posted on Apr 03, 2011
I need help with a 2001 ford f150 xlt data link pinout pin 16 showing no power i check the fuse are ok but cigarette lighter works i need a wiring diagram.
https://www.google.com/search?client=aff-maxthon-maxthon4&channel=t27&q=2001%20Ford%20F150%20XLT%20Wiring%20diagram
May 09, 2017 | Ford Cars & Trucks
Need pinout for wiring purposes
Most motherboard manuals diagram and describe the pinouts for most plugs on the board. You should be able to determine the answer by looking at the mfg website.
As you did not specify what you are looking for, no one can answer your question.
Jul 16, 2014 | Computers & Internet
Vga wiring i want to know what each coler wire represents so i wont burn my pc wiring my stuff into it
Here's some wiring diagrams:
First according to pin: http://hot-flash-games.com/web/vga%20cable%20pin%20connection-2875.html
And in this post you have pinouts according to standard color: http://www.diyaudio.com/forums/diy-projectors/30458-vga-pinout-wire-colors.html
db15 male
1)brown
2)red
3)orange
4)salmon
5)yellow
6)dark green
7)light green
8)dark blue
9)NC
10)light blue
11) purple
12)grey
13)white
14)black
15)brown/black
DB15 Female
7)light green
2)red
11)purple
13)white
1)brown
6)darkgreen
8)dark blue
10)light blue
3)orange
that's all oh yes you also have a ground wire from connector base to connector base.
Hope this helps. So from these two, you should be able to figure out witch wire is witch. Let me know if you need more detailed information.
May 03, 2011 | VIA ASUS A8V-E Deluxe K8T890 chipset...
The 3.5mm audio plug broke off on my Beyerdynamic headphones. I need to replace the plug. There are four conductors but I don't know what type of plug to buy (4-pin?) or what the pinout is.
Two of the wires are ground (-) and two are hot/signal (+). You'll need a stereo 3.5mm mini plug (try your local RS...they also call them 1/8" plugs). The stereo plug will be divided into three separate connections called Tip, Ring and Sleeve. The Tip is right channel signal, the Ring is left channel signal and the two grounds should be connected to the Sleeve or ground connection.
If you get one side of your headphones backward (out of phase, plus and minus backwards) you'll know by the sound quality and so reverse the wires of only one side to correct.
Apr 13, 2011 | Audio Players & Recorders
I don't know which wires to connect and to which slot it should be connected
The most important cables only FIT one plug. If it fits in one but will not fit in ANY others. Thats probably where it goes.
If you need to know which wires for your case such as front usb slots try this pinout diagram
http://image.pinout.net/pinout_files/standard-usb-pinout.gif
Otherwise you will need to be more specific.
Mar 15, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
VGA connector on a Dell e770s 17 inch monitor has been cut. Need to know where the wires go on a 15 pin db connector?? Can anyone help...Thanks gvp
Found out the information thru this page. Its a diagram of the 15 pin VGA Pinout and where the pins are supposed to go and what there fuctions are, hope this helps. Page is courtesy of pinouts.ru
http://pinouts.ru/Video/VGA15_pinout.shtml
Aug 29, 2009 | Computers & Internet
Have new dx959 doesnt get out very far talking 100yrds or so use rdking 56 mic mic works fine on old radio pc 78 and gets out fine also are 959 radios ok or junk has good reception
The DX959 has an output power setting knob. It's located next to the channel selector and is labeled RF Power. Turned counterclockwise will reduce output power. Turned clockwise will increase output power. Your switch is probably turned all the way counterclockwise resulting in low transmit volume.
Also, make sure the wiring for the RK59 is correct for the Galaxy. Even though it's a 4 pin plug, the pinouts may be different for the Uniden and Galaxy radios. Do a Google search for mic pinouts for your two radios to check.
Jul 12, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Would like to connect i pod into my system, but have no instruction book or wiring diagram. The model is a Sony CDX 5470 RDS
I just did this yesterday with my Kenwood MP8017 and an old Dell Pocket DJ. The deck uses a 15pin DIN connector. I had the connector and just used trial-and-error to determine the left, right channels and ground.
For your setup, you need to first determine what sort of inputs that the Sony unit has. Most have some sort if DIN input. If there is an AUX input, you are good to go as it is simply GND, Left and Right Channels. Then use this to deterime the signal pinouts from the IPOD cable.
You will have to hack up an IPOD docking cable (you can get them cheap here.). and get an 3.5 mm jack to cut up as well.
If your deck uses a DIN connector, you will have to source one of those and determine its pinout. Then, just match it with the IPOD connector and you are good.
Apr 20, 2009 | Sony Car Audio & Video
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
