Question about Dell Precision 380 P4 Dual Core 3 GHz (99382) PC Desktop
I have a Dell Precision 380. When I plug it in the power light (on power switch) is amber and the 4 light comes on. Fans are running and can hear the hard drive spin up. Nothing on the screen. I have read the 4 means Bios failure, does this mean mobo is hosed? Any help please....
    Problem Solver:
  • 5 Answers
Could be a bad capacitors. Open up the case and see if you have any bulging caps. The second thing I would try is to remove all the ram and reseat each ram stick. The 380 can be fickle about ram placement.
Posted on Apr 03, 2011
Yellow Amber light on Dell Optiplex 390 not booting or display what to do?
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 21, 2014 | Dell Precision 380 P4 Dual Core 3 GHz...
Dell Precision T3500 wont boot 1-3 lights blinking
An amber light means your computer isn't reading the hard drive or CD right, Take it to a professional to get this corrected
Dec 16, 2013 | Dell Precision Computers & Internet
Dell optiplex 380 won't turn on
steve it can be many things.3-4 but you don't give enough information
Apr 03, 2013 | Dell OptiPlex 380 MT Desktop Computer...
Dell opitiplex 280 is not giving display. first of all his fan speed to much high and then after 4 or 5 day its display disappeared. its just picking now power and fan also start with high noise and...
OK, I use GX280s as home servers and ran into a similar problem with one of them...
The problem may be serious and not worth fixing (motherboard).
Turn power on
Fan(s) come on full power, sounds like a jet engine, or eventually gets that loud.
See if you power light has gone amber.
You get nothing on the screen, no Dell splash screen/post, nothing.
This is what I posted a while back concerning the above. Obviously I cannot bee 100% certain as I do not have your box in front of me. This a known issue.
See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans go full blast . Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad. Bottom line this is usually a defective motherboard. Mine was a bad caps issue, you issue could be different, but it does sound like the motherboard.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one link.
http://community.spiceworks.com/topic/111476-gx280-solid-amber-light-and-loud-fan
I just replaced one of my old 280s with a dual core Dell Precision 390 workstation for about $118, and that included shipping, off of ebay.
Sep 25, 2011 | Dell OptiPlex GX280 PC Desktop
I have a Dell Precision 620 and the problem with running a PC. When I press the button, only yellow light is present and nothing happens. Control LEDs (4 pieces) on the rear side of motherboard does not...
Having worked with Dell computers before I have found that the amber light usually means bad power supply.
Get a replacement power supply from a know working Dell machine as their power supplies are different from standard ATX power supplies.
Regards.
Jan 13, 2011 | Dell Precision 620 PC Desktop
I got a dell precision 380 has a green light on motherboard but not switching on
i think you dont have proper power coming try to stabilize the power and try changing the ram slots if this does not work then i think you have blown your motherboard
Mar 17, 2010 | Computers & Internet
Take a 2-CPU Precision 670 down to 1-CPU
You probably removed the "primary" CPU,
and the computer cannot operate only with the "secondary" CPU installed.
Move the CPU from the "secondary" slot to the "primary" slot.
Jan 13, 2010 | Dell Precision Workstation 670 PC Desktop
Dell percision 380 workstation flashing amber light with lit up 2 on front panal. I got it to boot passed bios once into windows, windows says new hardware found do you want to resart, I answered no.then...
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Oct 13, 2009 | Dell Precision 380 P4 Dual Core 3 GHz...
DELL PRECISION M50 POWER CHARGING LIGHT ON BUT WON'T TURN ON
Try reseating the processor. Go to Dell.com and download repair manual. I have seen this same 3 lights a couple of times on c840's (same machine) when I forgot to lock the processor cam in place...
Jan 02, 2009 | Dell Precision M50 Notebook
Computers & Internet Logo
497 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
