Question about Coleman Heating & Cooling
Basement air in a winnebago 2000 adventurer. The ac makes a buzzing noise about every 90 seconds. It lasts maybe 10 seconds. Like the compressor is trying to turn on. It is 100 degrees here .We changed out the run and start capacitors about 3 months ago, but the symptoms were different then. but now, at least one compressor is working. What do we try ? Must we turn off the ac completely until it is fixed ? Thank you. Pam
  • 7 Answers
SOURCE: ac fan not turning on I can ''stick start it'' but which direction?
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Posted on Jun 26, 2009
motor1258
  • 6674 Answers
SOURCE: RVP 8000 Series Compressor wont stay running.
Try shutting everything else off temporarily that would draw any hydro in the unit, or even shut off all breakers except AC, and see what happens. See if it runs longer with everything else off. Double check nothing else on same circuit as your AC, and also confirm that 12/2 & not 14/2 cable size used for AC.
Posted on Jul 20, 2009
  • 4 Answers
SOURCE: Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
Posted on Jul 26, 2009
TheMobilian
  • 8220 Answers
SOURCE: Bad compressor or bad capacitor??
Look at the capacitor. if it is leaky or swollen it is most likely bad
Posted on Sep 12, 2009
Testimonial: "Thank you for your response."
  • 88 Answers
SOURCE: AC compressor won't start
hi,you might need a new compressor...you will need need to go back were you bought capacitor...buy a hard start capacitor too..this might crank the compressor...hope this helps.if you buy it..call an ill tell you how to wire it...if it dont ,you need new compressor...call michael..doctor airr..appl.repair...843-384-8474...
Posted on Mar 28, 2010
Heat Pump makes a surging/buzzing sound every 20 seconds
You might have a short going to your reversing valve. Check the temperature of all three lines out of the valve. The one on the left should be cold and the one on the left should be warm hot. . Check voltage to the valve.if it fluctuates that might be the reason for the buzz.
Mar 04, 2015 | Heating & Cooling
I have a 2000 36' Winnebago Adventure that got a power surge and burnt out the circuit board and capacitor in the coleman Central Mach ac and Furnace can someone send me in the right direction for
Check here and find your service manual as well as parts. If not 100% sure on what you need, call, or e-mail them, or get back to me with more info on who diagnosed problem, and more on symptoms you are experiencing.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Sep 13, 2012 | Coleman Heating & Cooling
Buzzing after replacing battery
Battery Disconnect or Replacement Problems
Listen under the hood in engine compartment , see if maybe your mistaken . Disconnecting the battery could cause Electronic throttle control to cycle the throttle plate , DC electric motor on the throttle body . Without hearing for myself ,that's the best i can come up with . Looking at factory service info. ,wiring harnesses , relay's , control modules . I don't see anything behind the instrument panel that could cause a buzzing
Dec 29, 2017 | 2004 Buick Rainier
It is making a buzzing sound
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Asker's Testimonial " Very helpful. Will give it a try and let you know outcome. Thanks!!! " - mibarra20605
Apr 12, 2010 | Amana DRS2660B Side by Side Refrigerator
My air conditioner is on but not blowing cold air and buzzes
The compressor is not starting. The buzzing noise you hear is the compressor trying to start and then the thermal overload trips. When it cools it will try to start again. Could be a bad capacitor or the compressor is bad. These two units need to be tested to see which one is bad. A capacitor is inexpensive. If it's the compressor it will be cheaper to buy a new AC.
Aug 21, 2009 | Heating & Cooling
Ac fan not turning on I can ''stick start it'' but which direction?
Jun 26, 2009 | Carrier Heating & Cooling
Goodman Condenser - Heat - Buzzing Noise every 60 seconds
It could be your compressor trying to start but not being able to do so. It shouldnt happen that often but in cold temp the overload protector may cycle that quickly. I reccomemnd to have it checked to salvage the expensive compressor.
Dec 24, 2007 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
589 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
