Question about Delta Faucet Signature Single Handle Kitchen Faucet with Matching Side ....
New faucet in December - water barely comes out of spout - sprayer works fine
    Master:
    Sergeant:
  • 500 Answers
Remove the areator see if water comes out spout better if so clean out aerator they get limed up or get junk in it..
Posted on Apr 03, 2011
Water won`t come out of kitchen sink spout,sprayer works fine
is it an old faucet? Did it just happen all at once? More info is needed to know what to do.
Jan 08, 2013 | Plumbing
New kitchen faucet installed just a trikle of water comes out hot & cold, sprayer is fine
remove the fitting at the end of the faucet, it just unscrews off the end,, when you replaced this, and had the water off, many times the rust in the pipes will break loose and follow up the faucet , which clogs in the fine screen located in the piece at the end of the spout ,, just clean it out and you should be ok
Sep 26, 2011 | Plumbing
I have a brand new moen muirfield high arc faucet with low pressure at spout but good pressure at side spray what can i do to get better pressure at spout
clevine336-
The design of a hand sprayer is meant to provide a higher pressure spray (the smaller outlet size means greater velocity in the water coming out of the sprayer head). That said, there could be something constricting the water flow in your faucet. If you unscrew the aerator on the end of the faucet do you get better pressure? Is the screen in the aerator clogged with sediment or mineral deposits? If this is the case you may have water requiring periodic cleaning of the aerator.
Hope this helps.
Regards,
DIYpro
May 01, 2011 | Moen Muirfield Kitchen Faucet with Side...
Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
Moen has a diverter built in that will need to be replaced.
use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
use a non silicone faucet lubricant when putting back together
Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Faust sprayer doesn't work
The problem is probably in the floating valve that is located under the spout. This valve floats up and into the base of the faucet when you push the handle on the sprayer to use it. This redirects the water to the sprayer.
They get stuck and then don't close off the spout properly
Short of teraring the faucet clean apart they are almost impossible to fix. Turning the water off and disconnecting the supply hoses, then blowing air back through the faucet spout may dislodge whatever is in there. This has worked for me in the past... and it has not work also...
May be worth a try..
Heatman101
Dec 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
When using the hand sprayer water still comes out of the spout we have replaced the diverter several times. It works for awhile and the starts leaking again . The faucet is a rohl a1676lpwspn single hole...
This faucet is notorious for this problem it is a design flaw that the manufacturer will not own up to either live with it or as I recommend to my customers replace the faucet with a better more reliable brand.I wish there was a better solution
Nov 08, 2009 | Rohl A1676LPWSPN Single Hole C-Spout...
Water volumn is very low, hot or cold. Barely a
take the aerator off the outlet or spout, it's clogged.
Jun 26, 2009 | Price Pfister Marielle Kitchen Faucet with...
My divertor switch/knob is not working
sound like the diverter is piped in backwards.
Mar 24, 2009 | Plumbing
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Kitchen spray not working completely.
Make sure the sprayer is clean of debris. IF YOU HAVE HARD WATER, soak in CLR overnight. If sprayer is clear then its the diverter which is more indepth thru the stem.
Phil
Oct 22, 2008 | Delta 2402 Classic Single Handle Kitchen...
Delta Faucet Signature Single Handle Kitchen Faucet with Matching Side .... Logo
174 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
