Question about Panasonic Televison & Video
I have a dse g3292 tv i plug it in and a yellow light comes on and it wont go.what is wrong with it.and will it cost much to fix
3 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: We purchased Panasonic DSE 32"
To start with, this is an internal failure as you might have observed. There could be many reasons for the same.It could be a faulty Z or Y board ( the cost of these board would be around $100 ) or it could be a a faulty logic board ( the cost of which would be around $75 ).Another reason could be a faulty inverter.You could rule out inverter by following the below technique ( this is not 100% foolproof, however would give you the best possible result without instruments ) :-
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
Ideally,the inverter must be tested by reading voltages with a multimeter.
I am sure that the above information must have given you an idea of the repair cost. You need to add the labor cost and the shipping charges ( if any ) or trip charges if you call a tech to get it repaired.If you wanted to fix it yourself, revert and i could tell you the place to order service manual and then provide some pointers on how to fix this. However, you need to have electronics repair experience, should be able to read schematics and needs to keep all precuations to resolve this problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 09, 2010
Hi!! we''ve got this DSE 32"plasma tv Model G3292 problem with this it has black smudge thing on screen n picture is like rainbow in colour!!My question is how can u fix this? sound is ok!!
Thank u
Posted on Jul 03, 2013
It wont turn on
It's obviously beyond your expertise to repair it yourself. And it's not the sort of problem that can be diagnosed over the internet.
Find a trustworthy repair shop and take it there. You can find repair shops in the Yellow Pages. Don't be afraid to ask if the repair cost is such that it would be more cost-effective to replace the TV.
Sep 05, 2012 | Polaroid 37" FLM-3710 HDTV Ready Flat...
Hi, my ps3 wont turn on, but the red light flashes green, yellow and then red again, Whats wrong with my ps3? My ps3 will be plugged in, turned on at the back, so the red light in the front is on. When...
i had the same problem. cost $70.00 to get it fixed. it is just temperary. 4 month warranty,it did the same thing again. an ower of a computer shop said they use to fix them, but it was not worth it. they all last that long and then would have to be replaced.after being fixed the first time.
Mar 30, 2011 | Computers & Internet
Dead, no power
It sounds like ze power supply blew when it was being turned off. This seems to be typical of plasmas. Bad power supplys wont let the tv come on and will result in no lights coming on. Since there R no lights coming on, I would suspect the power supply first, followed by the power control board,. and circuit board. It may cost anywhere from $250 to $500 to fix.
May 14, 2009 | NEC PXT-42SX1B 42 in. Plasma TV
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Mar 25, 2009 | Beko 324250WN 28" TV
My Daewoo TV is showing a yellow tinted screen...
this problem actually come from crt socket ic board (just patch behind the picture tube) need to properly clean and resolder back the joint please consult with your tv repairer and i think it not cost much
Mar 24, 2009 | Daewoo DTQ-19P2FC 19" TV
My Toshiba 50 inch projection screen TV isnt displaying
If you are capable of some basic troubleshooting you can determine what's wrong but you won't likely be able to fix it yourself. If you remove the TV's back panel, you can locate three plug connectors for the convergence correction yokes. You pull the red, blue, and green connectors and then plug the TV back in and hit the power button. If the TV comes on, its a failure of the convergence output ICs and will cost $350-450 if you call in a service company.
michtech
Feb 14, 2009 | Toshiba TP50G60 50" Rear Projection...
RCA L32WD22 Screen Blank, Green Light on
in the power supply you have six
Electrolytic capacitors you have to take the cover off the power supply to get to them. 3 of them will be 1000 uf @ 16v and the other 3 will be 1000 uf @ 35v the tops of them will probaly be bulged up replace those and that should solve your problem. you can replace all 6 with 1000 uf @35v and get them at radio shack for $1.79 each.
Jan 15, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
TV Repair
was the set good to you in them 10 years if yes put it to rest,the cost exceeds replacement value and the weight alone will take a toll on your body. let it go/
Aug 30, 2007 | GE 35GT695 TV
Samsung tv stoped working, it now wont power on, the red standby light dosent come on.
Yup I would tend to agree it's probably the PSU... It shouldn't be too expensive to fix, probably an hour or so labour and either parts OR a complete new PSU, in saying that ensure ya take it to a reputable service place.. and get a "quote" B4 allowing to continue.
Jul 30, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
96 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
