Lost program manual for Hunter 44377 thermostat. Is a MON considered from 12:00 midnight Sun night to 1200 midnight Monday night? etc. How can I program a Mon as if I were away all of Mon having only Wed and Sunday as having active at home days?
4 Suggested Answers
  • 117 Answers
SOURCE: Programmable thermostat
Basically, your going to press either of the arrows until it flashes, or about 1 second.
Then you set the temperature you desire and then press and hold the HOLD button until HOLD is displayed in the display.
Congrats, your on a permanent hold.
Then your next step would be to go get a real thermostat, install it on the wall, and then throw that piece of **** Hunter out the window as hard as you can.
The biggest problem with the Hunter stats is that they are cheap. On top of that, the programmable stats have a factory set program that cannot be simply deleted. Its always there, no matter what you do. And it makes for hassles when it goes back to factory settings and you either have to painstakingly re-program it or deal with the factory settings.
Here is a link to the Hunter manual.
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/43153.pdf
I would recommend to you the Honeywell line-up. The Visionpro 8000 series is a very nice and user friendly thermostat. Its the same one I have on my wall. Very easy to use and understand. Its touchscreen and the screen can be locked to avoid unwanted use of the system.
Posted on Jan 14, 2010
  • 5342 Answers
SOURCE: I bought a house with
To change the time, press Hour once. Then press and hold Hour to until it reaches the correct one (pay attention to the AM/PM notation). Do the same with the Min and Day buttons. Press Return when done. (The thermostat will leave return to the normal mode after 10 seconds without a button press.)
Now to set the program, set the switch to heat or cool depending on which you want to program first. Press Prog (this will program M-F settings) then press and hold Hour until the time you want Prog 1 to start. Press the Up or Down arrows to get to the temperature you want to reach and stay for this period. Press Prog again and use the Hour/Min/Up/Down keys to set the time and temperature for next period. Repeat for program 3 and 4 for weekdays. Press Prog again to do the same thing for the 4 possible weekend program segments. Any time left at 0:00 results in a program being skipped.
Press Prog to set the Program. These settings will not take effect until the next time change in the program. You can review the settings by pressing Prog and scrolling through the settings.
Change the switch to the other setting and repeat the programming if your system has both AC and heat.
If you want to press the AutoProg button the thermostat will use preset times and temperatures. For Heating that is 5 am 68, 7 am 60, 3 pm 68, 10 pm 62. For cooling it is 5 am 78, 7 am 85, 3 pm 78, 10 pm 82.
For more information, you can get the manual from Hunter: http://www.hunterfan.com/Support/Manuals-and-Parts-Guides/ , just enter the model number in the Search line.
I hope this helps.
Posted on Aug 17, 2010
Is TI chip covered on samsung dlp model HLT6187SAX/XAA?
I don't believe the manufacturer is covering this any longer, but you can try calling Samsung support at 1-800-726-7864 Call 1-888-899-7609
Mon. - Sun. 9am - Midnight (EST) Hearing-Impaired (TTY) 1-888-899-7608
Mon - Sun : 9am - 6pm (EST) Home Appliances Hours of Operations Mon - Fri : 8am - Midnight
Sat : 9am - 5pm
Sun : Closed Laptop, Printer, Galaxy Tabs (WiFi only) 1-800-SAMSUNG (1-800-726-7864)
Mon - Sun : 24hrs
the part# for your DLP chip is : 4719-001985
see the following web site: http://www.samsung.com/us/support/contact
the
Jul 06, 2014 | Samsung DLP HL-P4663W 46" Rear Projection...
Are the 7 different programs for 7 different days or are they exclusive?
There are 7 ON events and 7 OFF events
http://waterheatertimer.org/pdf/Woods-59028-59018.pdf
When programming the timer, you select individual days or blocks of days.
For example program1 ON time
Set the Hour
Set the minutes
Press the day key to scroll through the possible choices.
Then you set program1 OFF time
Set the hour
Set the minute
And then press the day key to scroll through the possible choices.
The choices are:
Each individual day
Monday thru Friday
Sat-Sun
Monday thru Sat
Monday thru Sun
Monday-WED-FRI
Tues-Thurs-Sat
Mon-Wed
Thurs-Sat
The key is to set the ON and OFF times for the same days or blocks of days
For example program1 ON is 8:00 am Mon thru Friday
Set program1 OFF for 3:00 pm Mon thru Friday
and then program2 ON is 8:30am Sat-Sun
program2 OFF is 5:00pm Sat-Sun
Program 3 ON is 6:00pm Tues-Thurs-Sat
Program3 OFF is 9:00pm Tues-Thurs-Sat
Program4 ON is 6:00pm Sat
Program4 OFF is 11:00pm Sat
Programs5, 6 and 7 might not be needed
The key is to make a chart of times before setting timer.
The chart will prevent conflicts in programming where the timer does not operate as expected.
Nov 08, 2010 | Coleman Cable Woods 59018 InWall 7Day...
I f u can give us service center her in manila thank you
ASUS Philippine Call Hotline:1800-1441-0573 (10:00-21:00 Mon. ~ Fri.)
Please call:+63-(2)-636-8504 if you use mobile phone.
Asusworld Megamall
+63-(2)-6382955 (10:00-22:00 Mon. ~ Sun.)
SM Megamall 4th Floor Cyberzone Bldg. B Mandaluyong City
Tekzone Makati
+63-(2)-8128976 (08:00-18:00 Mon. ~ Fri. / 09:00-12:00 Sat.)
7185 Export Ave. corner Chino Roces Makati City
Tekzone Cebu
+63-(032)-4227510 (08:30-18:00 Mon. ~ Fri. / 09:00-12:00 Sat.)
E-14 J Kings Warehouse Complex Hernan Cortes Mandaue City
Servimax Technologies Inc.,
Unit G, Gilmore Commercial Plaza
#10 Gilmore Avenue, New Manila Quezon City
Phone: (+632) 721-9102 and 722-2992
Fax: (+632) 721-6819
Schedule 10:00 - 19:00 Monday to Saturday
ASUSWorld Virra Mall
4th Level VMALL Plaza Greenhills, San Juan, MM
Phone:+632 584-2612
Schedule 10:00AM - 20:00PM Monday-Sunday
AW Gilmore Zone
3/F Gilmore IT Center Bldg., #8 Gilmore Ave., cor. 1st Street, New Manila, Quezon City
Phone:+632 994-3696
Schedule 10:00AM - 19:00PM Monday-Sunday
SUWERTE,
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 24, 2010 | ASUS Computers & Internet
Module 3070 - PAW1300 > AM / PM problem apparently. Everything works except day and date 12 hours behind. EX: In HNL (Honolulu) on Monday morning, September 6 watch gives correct time, but shows SUN...
Hi, Obviously you need to roll the time 12 hours ahead. If the watch doesn't receive the Atomic signal properly at first, go to page three of your manual, and try doing it manually following the detailed procedures there.
If you don't have the manual, get it here:
http://world.casio.com/wat/download/en/manual/
Take the four-digit (3070) module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Sep 07, 2010 | Casio Pathfinder Watch Green PAW1300 3V
The day of week is wrong on my partner-18D (lucent avaya phone)
Dial Feature 00
Left Intercom Button Twice
Dial #102
Dial 1 for Sunday, 2 for Mon, 3 for Tues, etc
Dial Feature 00 to save your changes
Nov 19, 2009 | Avaya 700340193 Corded Phone
Hunter 44155C Thermostat
Try calling hunter directly at 1-888-830-1326 to speak with a live support representative. If you are still having problems.
Jan 26, 2008 | Hunter Fan Company 5/1/1 Programmable...
Setting the time
At extension 1
press Program (mute light turns on)
press Transfer (mute light flashes)
dial "38"
enter 2 digit year, i.e. "08"
enter 2 digit month, i.e. "05" = May
enter 2 digit day, "01" = first of the month
"31" = last day of the month
enter 1 digit day of the week
1=Sun, 2=Mon, 3=Tue, 4=Wed, 5=Thu, 6=Fri, 7=Sat
enter 2 digit hour in 24-hour format
00=midnight
01=1 AM
13=1 PM etc
enter 2 digit minute from "00" to "59"
press MUTE.
You will hear a single confirmation beep. If not, you did something wrong. Start again from the top.
Nov 29, 2007 | TMC M4810 NON-KSU Corded Telephone
Hunter programable thermostat
google search hunter thermostat and the model number and manual and it should come up, I found mine with "hunter thermostat 44200 manual"
Nov 25, 2007 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
