Question about Hoover UH70210 Bagless Upright Vacuum
My brand-new Hoover T-Series Windtunnel is making a knocking noise as the belt spins and the roller clutch doesn't disengage as far as it should. Its worrisome only because I just pulled it out of the box and as far as I know there aren't any adjustments that should be made. Or can be made for that matter. Any suggestions?
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
  • 97 Answers
SOURCE: Hoover Windtunnel shuts off
Sounds like you have a clog, which is a fairly common problem with these.
Check the air inlet immediately aft of the brushroll for clogs, then make sure the main wand and hose are also clear. If you have the machine on, check at the end of the hose for suction. This is a fairly common problem for all uprights with tools on board. Their airflow is very low, so they tend to clog up easily and then overheat the motor.
-R
Posted on Oct 01, 2008
SOURCE: brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Posted on Jun 04, 2009
SOURCE: auto brush on hoover windtunnel doesn't spin anymore
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Posted on Jul 09, 2009
VacuumRepair
  • 438 Answers
SOURCE: I have hoover WindTunnel Self Propelled Vacuum
Greetings from GoVacuum,
Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at chris.jones@govacuum.com if you have any questions about the repair!
Video Repair of Hoover Windtunnel Belt Change
Thank you very much!
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
Hoover Windtunnel model U6485200B troubleshooting brush not spinning
Hi! The brush-roll feature needs to be engaged for the belt to tighten, so when checking the belt it will appear to be loose. Be sure you have replaced both belts on the vacuum with genuine Hoover parts. This unit takes belt 38528034 and 38528035. Also, make sure the vacuum is on carpet mode. Follow the link to view the instruction manual which provides instructions and illustrations on changing the belt to be sure it is assembled properly.
http://hoover.com/file/509/
Hope this helps!
Aug 08, 2014 | Hoover Vacuums
Changed belt. have burning smell
Take it back apart, check it again. Check the plastic where the belt is running for burnt spots. Also check the brush roller sometimes the tension from a new belt can finish off what was left of the bearings and cause the plastic end caps and roller to melt. Pull out the roller and try to spin it while holding the end caps. If it doesn't spin or spins hard there's your smell. Most times when the rollers go bad they break the belt. Replace the roller if necessary Make sure the roller is in correctly and flush and that the bottom plate goes on easily.
Good Luck
The Vac Dr.
Jan 12, 2013 | Hoover U5434-900 WindTunnel Plus Bagged...
Hoover windtunnel t series belt is loose- roller brush doesnt turn. Its brand new belt is slipping. we bough new belts and putthem on same problem. Can not find solutio in manual. Is the belt supposed to...
I also have a loose belt and have bought additional belts but have the same problem. I put the it around the metal rotor and around the brush roller a shown by he Hoover video, and it is loose.
Nov 28, 2010 | Hoover S3765-040 WindTunnel Bagless...
Hoover U6637-960 the self propel is not not working. When lowering the handle it acts like it would like to work but the roller will not turn. appears to be something to do with the self propel part of the...
This vac has 2 belts. If both self propel and roller not spinning then most likely it is the wide flat belt broken or off. 4 screws on the bottom should gain you access to the belt area. another issue for this model series is a worn pulley on the roller, a new belt when inserted around the roller should be even with the top of the pulley groove.
Apr 17, 2010 | Hoover U6630-900 WindTunnel Bagless...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Replaced belts and brush roller will not rotate.
check to see if the spindle (small pencil-thin metal rod) is spinning where it projects from the motor. the belt wraps around this rod. if the rod is spinning when the vac is turned on your brush roller could be jammed. the bearing in the far sides of the brush roller frequently pick of long threads and hair and will stop the brush roller or the bearings sometimes overheat when worn and plastic will melt in this area causing stoppage.
Jul 10, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush roller on windtunnel won't spin
Mar 21, 2009 | Vacuums
I have a Hoover WindTunnel, Self-propelled model, and it was working great until I ran over a portion of the cord, then it started making a bad noise and I noticed the roller is not moving consistently...I...
The V belt usually wears down first. Remove the roller and belt to visually check for wear and belt material in the roller pulley. I would change the flat belt as well. Also, replace the cord if any wires are exposed
Mar 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover very noisy after new belt installed.
what is the belt # you have installed (generic)? Yes, there are problems with using generic belts on Hoover Vacuums. If you have noise I would suspect the roller, and replace it. the cost is about $25 and is something that you can install. The newer type are mande of wood and are very quiet.
Nov 23, 2008 | Hoover U5753-900 WindTunnel Bagless...
Brush on vac
I don't know how old your machine is, but the belt should be changed at least once a year and you should check to make sure the roller spins freely. There are bearings at either end of the roller and they will become contaminated with dirt and hair after a while and will need to be serviced. A new belt will help, but won't last if the roller is in need of service.
Dec 02, 2007 | Hoover U5753-900 WindTunnel Bagless...
Hoover UH70210 Bagless Upright Vacuum Logo
67 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
