Stuck in standby mode
My machine has gone into stand by mode and won't turn on again can you help
  • private33 Oct 28, 2008
    I am having the same issue, I have gone so far as to remove the hard drive and boot up in just the BIOS mode. no joy. hard drive works in my other laptop. the one in question worked fine in the docking station but won't turn back on once removed. using known good battary and AC cord.
  • 3,051 Answers
Unplug the cord from the power supply open the case and disconnect the cord from the power supply to the motherboard then press the power on button this will release the leftover electricity from the motherboard than after 30 seconds plug the cable back into the motherboard and plug in the cord to the power supply and try to restart the computer ok please let me know how this goes goood luck
Posted on Aug 09, 2008
Panasonic viera problems
The internal power supply is failing
Jun 15, 2013 | Televison & Video
My p315 speaker stays on standby and won't power up?
some design need audio signal in to get it wake up from standby mode.
Oct 25, 2012 | Acoustic Research P315 HO Speaker
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Standby mode is not working..
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, would suggest going into the CMOS/BIOS setup and restoring all configurations/settings back to default. Should this be not corrective, try verifying settings inside the Properties box of the Power Options inside Control Panel.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 13, 2008 | Acer Aspire 5000 Notebook
goto control panel and double click on "power options" under that aplet is the settings for standby and also hibernate.
Dec 07, 2008 | Computers & Internet
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | JVC XV-523 DVD Player
About laptop
Generally you can just hit the space bar a couple of times, and that should bring the machine out of Standby mode. However, if it is not Standby but Hibernate mode, you usually need to push the power button to bring it back from Hibernate.
You can adjust these and other power settings by going to the Control Panel, and clicking on the Power Options applet.
Feb 11, 2008 | Computers & Internet
Stuck minidisc
Turn the power off and back on at the mains. With the machine now in standby, press and hold the "Play Mode" and "Minidisc Play/Pause" buttons together. The machine will enter test mode and the disc should eject. Switch the power on and off again at the mains and the machine should be back to normal.
Oct 16, 2007 | Sony DHC-MD333 Shelf System
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Computers & Internet Logo
476 people viewed this question
David Payne
David Payne
