How to use cam how to set it up and settings - Computers & Internet
  • 409 Answers
  • You must have a software CD for the cam you have.
  • Run the CD in CD rom and install it in your pc.
  • Finish the processes and restart your PC
  • Connect the cam and enjoy.
USE SKYPE FOR VIDEO CALLING. Thanks for rating Good luck
Posted on Apr 03, 2011
2004 honda accord ex 2.4L, how do I set cams before putting on timing chain?
Not with the valve rockers in position. If you do then the valves will bend as they hit the pistons
Mar 14, 2015 | 2004 Honda Accord 2.4 EX
Trying to time the cams shafts to the belt pullys there no notches only 3 bolt holes
You really need the Cam Tool that holds the Cams in place from the opposite end of the head as the Pulleys. There is also a Tool to hold the Cam Pulleys as well. IPD sells it for near $280 and that also includes the guides for the Cam Cover and a set up to evenly press the cam cover in place. The Cams will have a groove where the tool holds them and you will need to find out how they are supposed to be set. Just be happy you are not dealing with a Variable Cam Timing set up.
Feb 04, 2013 | 1999 Volvo S70
My webcam shows the reverse. what can I do to make it good
Normally you install software with a web cam, if you open the software that you installed with the web cam you will be able to locate a settings tab/button/area with various options for changing the web cam settings. If you're using you cam with a different piece of software there are usually similar settings within the software. Look for settings tabs or web cam settings tabs.
Aug 15, 2011 | Computers & Internet
How do i set cam position and timing on an old yamaha xt 500
You didn't say WHY the cam / valve timing needs to be reset. For some reason I get the feeling someone told you that resetting was needed and so you are asking how. Obviously, you may have installed new pistons and that is why the resetting is needed. In either event, when the cam timing is set the valve timing is also set. Other than adjusting valve lash, setting the cam sets the valve timing. Below is a web site where you can do a free download of a factory service manual. The process is not hard but having a manual will be more help and faster help than I can give online.
http://www.carlsalter.com/motorcycle-manuals.asp
May 25, 2010 | 1997 Yamaha XT 600 E
How do you set the timing on a 1998yz400 i recived this motor with the cams takin out and dont know how to set them
the cams should say ex, int on cam sprockets if not the cam with 3 lobes for intake cam with 2 lobes exhuast, piston at top then set the cams with cam lobes facing outwards almost like a VEE there is i think a dot on each cam gear which must line up with the head. then turn the motor by hand
Aug 09, 2009 | 2001 Yamaha YZ 426 F
Video call on skype
you will to disconnect the bluetooth cam from "remove hardware settings" or unpair it from the bluetooth setting icon on the bottom right
Jul 24, 2009 | Logitech Quickcam Chat Webcam
I need timing marks on 1997 cad.sev 4.6 eng
well you need to start from the crank and set that you will see a dot on the bottom gear set it straight up next the cams you have 4 cams all need to be set ok the cams will need to be set as follows the 2 inner cams next to intake manifold should be set at li,ri.........the 2 outer cams set at le,re 90 degrees straight offf the head
Mar 22, 2009 | 1997 Cadillac Seville
Stops taking pictures after approx. 128-130
Hi, Sue,
Not really sure on this, but if where he bought cam will take it back,try it...
However, it may not be the cam, but different resolution settings on the two different cams. Digital cams by different manufacturers format SD cards using different means; some allow more memory space on card for formatting than others..and if the game cam is set at a higher resolution than the other cam, then the 2nd cam might use space 1st cam left avail.i.e., say cam "sets aside 4mb of memory to format card, but only uses 2mb of this space. Now, the game cam is set for high resolution and take 130 pics @ 15mb each..15x130=1950mb,+ 2mb left by game cam=1952mb(1.952gb), or about 50mb of space left on card...put it into cam set for lower res. and might get several more pics before card was really full...be sure all is equal...both cams, and card,ect. 128-130 pics @ high resolution ain't bad....on a 4gb SDHC card with my I-40's set for High Res., I can get 1000 pics;@ enhanced and I get only about 300. Set at low res., and # goes way up.Hope you understand all this.
ron
Mar 11, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Starting troubles
Did you over haul the engine? If so please tell me how you set the cam timing. Did you install the int cam first? and there is a sequence for installing the cams. You need to make sure that at TDC on #1 cly both lobes of the int and exh cams are pointed down. There are dots on the cam gears that will line up parallel with the head when the cams are installed correctly.
Dec 11, 2008 | 1995 Suzuki GSX 600 F (Katana)
Webcam
Ok im not sure what cam you have or comp that your using, but cahances are you need to go to your web cam settings:START/ALL PROGRAMS/ "your cam"/ CAM SETTING. there you should see inverted or mirror settings, it might even be in ADVANCED SETTINGS try and look for it, Good luck JLS
P.S. you could always turn your cam upside down! LOL Just kidding!
Sep 21, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
