Question about Wharfedale PowerCube PC-12 Subwoofer
My wharfedale sub is making a loud intermittent crackling sound. It eventually when tested with a sub amp sound test stops putting the correct sound through altogether. I've established that it is not the amp to sub cable. Is it fixable?
Sub Speaker giving intermittent loud crackling and sharp loud popping sounds even with main volume control turned off. Crackling sound can be reduced by turning sub volume control off.
It may be the control itself too. In time, these controls can get dust build up inside it. There are volume control spray cleaners available from Radio Shack or other electronic parts stores. The cheat on cleaning the control is to just rotate it from stop to stop as many times as it takes to clear the noise.
Mar 17, 2016 | Altec Lansing Acs295 Subwoofer
Crackling
So if you bought enclosures that are premade AND had the speakers installed, you need to see if there is a cross over network installed in them
Apr 27, 2013 | Car Audio & Video
Hi, My Saffire LE is making a crackling sound. I have check this on both the monitoring channel and the second out put on my HS80's and also on the headphones out put on my AGK's, the crackle is...
Power sound amplifier output transistor push n pulls are dead and the q point is off the scale.
Either it is a modular amp or discreet top hat xistors
Aug 23, 2010 | Focusrite Saffire LE FireWire Audio...
My subwoofer makes a very loud shreaking sound consisting of a mixture of high and low tones (almost sounds like it is about to explode) after power has been on for about 5 minutes. I had the problem...
Did they charge you much for that 'fix'?
Though it may have become damaged in the original problem, the driver won't make loud sounds by itself in the absence of a signal. The internal amp is probably malfunctioning and it is very capable of destroying its own driver. Don't let it continue when it starts acting up.
Did it work correctly for more than 5 minutes after the driver replacement? Take it back and make them do it right this time.
I had a powered sub amp problem that the local guy couldn't fix so I just disconnected it and wired the driver directly out to a separate amp. Works fine as a passive sub.
Jun 11, 2010 | Wharfedale PowerCube PC-10 Subwoofer
I have a wharfedale svp15 passive loudspeaker. The subwoofer has started crackling and popping at low volumes and has no deep bass. At high volumes it sounds great as usual and can't tell if the crackling...
Information I find online says it an Active Subwoofer, so that introduces its own amp as a possible source of the symptom. If there is another version of this model that's passive, all the more reason to believe the amp is the problem because passive speakers don't spontaneously emit sounds.
If there was a physical reason for the crackling I would think more power would make it worse or blow it up.
A poor sub signal cable connection might explain low current anomalies if random noises are entering the signal path.
Make sure the signal, speaker and power cables are not aligned parallel and close to each other.
Feb 26, 2010 | Audio Players & Recorders
How do i know if my sub is blown?
The sound (if it makes any) will be distorted and garbled. Keep in mind that subs require amplification. If you are testing the sub without an amplifier you may or may not hear distortion because the radio by its self can't make the sub perform properly, if it has to low of voltage it may crackle because its not recieving a strong enough signal, if it is blown it may not crackle for the same reason
Sep 25, 2009 | AudioBahn AW100T Car Subwoofer
Creativr Gigworks S750 Subwoffer intermittent sound
The S750 system is a great sounding one but unfortunatly like many similar systems all the amplifiers and power supplies are housed inside the sub box. This means they suffer badly from heat and vibration problems (they cook themselves or shake themselves apart). I have fixed a few S750 systems in the past but due to their complexity it's not for the faint hearted.
May 26, 2009 | Creative Labs Gigaworks S750 Computer...
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
Wharfedale PowerCube PC-12 Subwoofer Logo
87 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
