Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
HOTPOINT AQUARIUS WASHING MACHINE.
CANNOT LOCATE FILTER ON WMA58.
  • Anonymous Aug 07, 2008
    we have got to the pipe but cannot undo the white plastic clips which holds the pipe on, any idears?
    President:
  • 1,462 Answers
At back, take small bottom panel off. you will see a large diameter hose going from bottom of machine to the pump. undo this hose at the machine end and the filter is inside the hose. take out and clean.
be carefull, lots of water will come out if the machine has not drained.
best to disconnect from mains when you do this
Posted on Aug 05, 2008
I have a hotpoint wma58. please can you tell me where the lint trap is located. thanks
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP ANY WATER BEFORE DOING ANYTHING!
Although I don't know your particular washer, the lint trap/filter is normally behind the front lower (kick) panel. This panel is probably held in by a couple of plastic screws which turn 90 degrees anticlockwise to release. The filter is normally held in by a round cover/knob which should be turned anticlockwise to release. THIS IS WHEN WATER MAY APPEAR!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
John C
Feb 11, 2011 | Hotpoint WMA58 Front Load Washer
Not all of detergent is flushed away
Check your hot water pressure you may have a bent or kinked hose or if you've had work done on your heating tank the filter in the valve may be clogged
Jan 31, 2011 | Hotpoint WMA58 Front Load Washer
Dont know where the filter is on an htpoint aquaris wma56?
if its similar to the WMA58 the filter is within the pump houseung one has to take the pump out disconect the tubes and you should see the filter in the center of the housing above the pump
Feb 16, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Where is the filter is
The filter is located at the rear of the washer.
Remove lower rear cover.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint WMA58 Front Load Washer
When on final spin, water leaks from detergent draw
You probably need to clean the filter.
Remove lower rear cover of washer.
Remove large black hose fastened to bottom of drum.
Remove hose onto pump, and check for blockage or obstruction here as well.
Thankyou.
Jan 18, 2010 | Hotpoint WMA58 Front Load Washer
Where is the filter
The filter is to be found at the rear of the washer.
Remove and clean filter located inside the hose.
Remove hose onto pump, and check for blockage or obstruction here and in the pump as well.
Hope this helps.
Dec 17, 2009 | Hotpoint WMA58 Front Load Washer
Hi i am having trouble with our wma58, the last 2 washes it has sounded noisy on start up but then washed fine yesterday i put the machine on it seemed to get half way through a cycle then stop all the...
Try the following.
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to the bottom of the drum.
Remove and clean the filter inside the hose.
Remove the black hose onto the pump, and check for blockage or obstruction here and in the pump.
Hopefully, this will solve your problem.
Good luck.
Dec 13, 2009 | Hotpoint WMA58 Front Load Washer
Where can I get a wiring diagram for wma58
Here's the user's manual....it should have the wiring included. Good Luck
Aug 11, 2009 | Hotpoint WMA58 Front Load Washer
Where is the filter located on the washing machine?
Remove lower rear panel, locate large black hose, unfasten, and you will find plastic `filter located inside hose, remove and clean.
Thanks.
Jul 06, 2009 | Hotpoint WMA58 Front Load Washer
Model wma58 as soon as the machine finishes it wash cyle and is to empty water gushes from them soap dispenser area .Is there a blockage causing this fault.
Probably blocked filter, remove lower rear cover, locate and remove large black hose on bottom of drum, remove and clean filter inside hose.
Thanks.
Mar 05, 2009 | Hotpoint WMA58 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
227 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
