Question about Stihl Chainsaw Cutoff Saw Flywheel 08 S Ts350 P835
My stihl ts 760 , no gas going to carb. I have changed all filter , fuel, air, all gaskets , all gas hoses, new decompression valve, plug, cleaned carb. was working before this . Any ideas?
  • Anonymous Mar 12, 2014
    Carb problems
Sounds like the diaphragm in the carby is shot, Ebay sells new complete carbies for $76. Also check needle and seat, by pulling off carby and blowing in the fuel inlet while the cover plate is off. push up and down on the needle and seat, air should go through when you have it open. Good luck
Posted on Aug 29, 2012
  • 718 Answers
Clean it again you missed something or maybe a gasket is on wrong. If you went through all of that it should run fine. Stihl usually rebuilds and runs well. Slow down turbo maybe you got a little ahead of yourself. Good Luck...
Posted on Apr 03, 2011
  • turbofrank26 Apr 03, 2011
    I was wondering maybe I have low compression ? How can I check besides removing the spark plug and blocking with my thumb ?
  • vince janis
    vince janis Apr 03, 2011
    You can set up a pressure gauge to check compression or take it to your local repair center and have them check compression but it might cost a little. If you try to make one yourself be careful to get the thread match correct on your plug hole.
Stihl TS 760 NOT GETTING FUEL TO CARB OR PLUG BUT HAS GREAT SPARK HAS SIT FOR A WILE POSSIBLY OUTSIDE IN ELEMENTS ANY SUGGESTIONS
What's the compression like.? The carb requires the vacuum of the falling piston to draw fuel through the venturi of the carb.
Check the fuel lines are not perished or split, and fuel filter is clean..
If all of those are good then check the carb, strip it and clean it, replace any fatigued diaphragms, make sure the needle isn't stuck in the sleeve.
Jun 02, 2016 | Stihl Garden
I have a stihl 015 no gas going to the carburetor I changed the gas line and filter & rebuilt the carb what should I look at
It is the check valve on the metering side of the carb. The one pressed in brass bushing with the small black check valve inside. Drill it out and cleaned the carb and jets well after. When you prime the carb you will get a little air back through the jets but I get a reliable repeatable fuel flow.
Apr 14, 2016 | Stihl Garden
Stihl chainsaw problems
Your dealer is right. Gas is not a carbs best friend. every time you fuel dirt gets in the fuel tank from the air. This eventually blocks air and fuel passages and check valves inside the carb. That is the reason. Carbs wear out like anything else. Check the price of a carb compared to a kit. Some Stihl carbs are reasonable.
Jul 21, 2014 | Stihl Garden
Stihl TS400 stone cutter not working (no compression) so replaced piston rings, new gasket kit and clean for carb new spark plug (good spark when engin turned over) cleaned all air filters, replaced all...
You did not indicate whether or not you have compression now that you have changed out the gaskets and piston rings. If not, it seems to me that the problem could be a) cracked head or block, b) bad valve(s) or even c) a warped head.
Sorry for the bad news (if I am right).
Apr 23, 2014 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Saw acts like it gets no gas
It could be a very large air leak, may be a crank seal has popped, of cylinder base gasket is leaking badly.
Sep 10, 2012 | Ryobi 18-inch Electric Chainsaw Chain Saws
My Brand new Stihl ts420 cut saw wont run full throtle, smokes white, and leaks fuel out of exhaust filter. it runs like the choke is half on.
This sounds like the carb is flooding, there is a rubber tipped needle under the metering side of the carb, this may be leaking, before replacing the needle make sure the air filter is not blocked, replace with a new filter and try again
Dec 14, 2011 | Stihl Ts 410 420 Cut Off Saw...
My riding lawn mower won't start. New battery (cables & connections are clean), new filter, plug, rebuilt carb. It's getting spark but won't start? I cleaned the magneto and flywheel. Any other ideas?
Spray starting fluid into the air box if it starts and dies out there is a fuel delivery problem if the mower has a petcock fuel shut of valve disconnect the fuel line after the petcock and hold a container under the hose turn on the valve to ensure gas flow to carb if there is no petcock valve I would still check the line to carb make sure gas flows through the hose to carb.
Jul 23, 2009 | Champion International Champion& Small...
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
STIHL TS 400 won't start
I just repaired one with a similar problem--not getting enough gas. Two things corrected it and both were carb related. First I replaced a rather stiff diaphragm with a new one and second I reset the intake valve to allow more fuel into the carb. That solved it. Good luck.
The gas filter is weighted and should remain at the low point in the tank so it is an issue only when you are about to run out of gas--unless gas has been sitting in the tank for a long time. That can leave a film on the filter that can restrict fuel flow. Pull the fuel filter from the tank and scrap lightly on the filter. You will immediately note if there is a film on it. If so, replace the fuel filter.
Mar 15, 2009 | Hand Tools
Stihl Chainsaw Cutoff Saw Flywheel 08 S Ts350 P835 Logo
589 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
rlev_7
Level 1 Expert
Spud Howell
Are you a Stihl Saw Expert? Answer questions, earn points and help others
