Question about Shakespeare Sport & Outdoor - Others
Shakespeare Silent Automatic (green) Model GB No.1837. The leader is intertwined in the spool with the yellow heavier casting line. How do I get the spool off to untangle the lines. I inherited the reel; so, I do not have a manuel. I want to learn to fly fish. This is my first fly fishing rod and reel.
5 Suggested Answers
SOURCE: Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
Posted on Apr 29, 2009
  • 7 Answers
SOURCE: I have a shakespeare sigma fishing reel that
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
Posted on May 21, 2009
  • 10 Answers
SOURCE: Shakespeare fishing reel schematics
try online at www.reelschematics.com they should be able to give you help.regards barry.
Posted on Sep 29, 2009
SOURCE: shakespeare 2660 coarse fishing reel,cant remove spool cover
absolutely spot on
Posted on Apr 18, 2010
Howtoseyupaspincastingreel
use 10# test line or heavier. use 3\8 oz lure or heavier. set magnetic control to "5". tighten small silver knob under the reel handle down until the spool will not turn when you push the thumb bar. loosen the same silver knob while you have the thumb bar pushed and adjust the knob tension so that the spool stops turning when the bait hits the ground. this is basic tuning for any baitcasting reel.
Jul 08, 2012 | Abu Garcia Pro Max Baitcast Reel
My line won't rewind on my Shakespeare Encore reel. After casting, the bail snaps in place, but when I reel in, the line won't reel in. The spool turns with the bail, but doesn't retriev
Your line is on the wrong side of the bail. Rethread the line so its over the bail so that after the cast you flip it up it catches the line and retracts it.
May 05, 2012 | Sport & Outdoor - Others
How to thread a Shakespeare fishing rod and reel
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
Jun 05, 2010 | Shakespeare Agility Spinning Reel 6825
Shakespeare ?Tidewater? reel
late response here, but it is worth noting that these reels need quite a bit of lure weight to cast easily. two or three oz and it will do very well. i use these for cats and love em. good luck
May 20, 2010 | Shakespeare Agility Spinning Reels
NEED INSTRUCTION SHEET FOR LINE INSTALLATION
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Oct 25, 2009 | Garden
How to I fix a spin casting reel?
You should be able to remove the spool by removing the knob on the front of the reel which also is the drag adjustment. With the knob off the spool should pull right off. Hope this helps you
Oct 18, 2009 | Shakespeare Agility Spinning Reel 6825
What do you do with the line before threading it through the eyes
Take the line off the spool in such a way that the line will be caught by the bail after you cast the line. The easiest way to get it right is to raise the bail like you are going to cast the line, thread the eyes, then trip the bail with the handle, as though you were reeling 'em in.
Happy fishing. I'm jealous.
Best regards, --W/D--
Jul 20, 2009 | Shakespeare Surf Fishing Rod and Reel...
How do you cast?
flip the bail(the round rod in front of the reel)hold the line tight with your finger first and cast(make sure you let your finger off the line when you throw the rod forward.
Jul 17, 2009 | Shakespeare Agility Spinning Reel 6825
I have a shakespeare sigma fishing reel that tangles up when I cast it, any solutions
May 18, 2009 | Shakespeare Surf Fishing Rod and Reel...
Sport & Outdoor - Others Logo
217 people viewed this question
Top Shakespeare Sport & Outdoor - Others Experts
Bill Eager
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Are you a Shakespeare Sport and Outdoor - Other Expert? Answer questions, earn points and help others
