Question about Vacuums
I would like to know how I can get a manual for an Alen Electrostatic Air Cleaner model KJ25FE-H1. Also I would like to know which air filter to buy for it.
Hi I have found a variety of manuals for you from the alen corp website
follow link http://www.alencorp.com/support.asp?globalnav
at bottom of page is a list of manuals hopefully one is yours if not you could e-mail them
Posted on Apr 03, 2011
My hoover sucked up water. I dried it out but I think some may have got through the filter to the engine as nothing happens when I turn it one now. Fixable? Miele c2 compact allergy
If the bag was wet and the internal filter that sits behind the bag on that model was wet then water will have penetrated through to the motor.
All you can do is remove all possible components from the inside of the cleaner (the bag and filters) , get a powerful hair dryer, set it on cool and run air through from the inside of the cleaner into the electric motor compartment to try and dry up any residual moisture. Leave it open to air out and wait a few days before refitting the components and starting it.
If it will not start after drying it then you will have short circuited and damaged the motor and you will need to buy a new machine.
May 30, 2016 | Hoover Vacuums
Rainbow vauccum D4C model
I think you made mistake of connections when reassembling the unit or place motor in wrong direction. Please open it again, if you opened it before, and check above said hints.
Sep 18, 2008 | Rainbow Vacuums
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
Filter cleaning
The fact is that the "bagless bandwagon" is powered by some excellent marketing that conceals what is often poor technology. In your case, the filter blocks because it's doing the job that a bag would do in a bagged machine (catching the dust), and then the machine overheats because the flow of cooling air to the motor is restricted. The only solution (for this machine) is to keep buying new filters - the only permanent solution is to buy a different vacuum cleaner. And my advice is to buy one with a bag!
Nov 03, 2009 | Dirt Devil M0105 Bagless Vacuum
My 4 yr old Nilfisk vacuum cleaner has been working fine up until now. But suddenly, it has hardly any suction power and also, hot air seems to be coming out thru the vents on top and also thru the space...
Hi there SmartAlec from Nelsonvacuums.com.au here.It sounds like a blockage of some kind. The best way to find it is to set the machine up for normal vacuuming and remove one component at a time until the suction returns. eg turn on and feel suction under floor head - not good? then remove the rod, then the hose.
Once at the machine on its own it gets a little triky as i don't know which model you have. However if you have a bagged model remove all the filters and the bag and retest. There will be at least 2 filters, one before the motor and one after (maybe under the vacuum or right at the back). If it is a bagless model even though the filter may look clean it is probably blocked with very fine dust. If suction returns when the filter is removed then you need to buy a new filter. I am a nilfisk vacuum cleaner agent so i can supply a filter for you.
If this still doesnt help you are welcome to call me if you live in australia my contact details are on my website www.nelsonvacuums.com.au.
Hope this helps !.
Happy vacuuming :)
Aug 23, 2009 | Vacuums
Can I wash filter in water
I haven't seen one, do you have an air compressor? You can blow it out.
If it's plastic it should be washable, if paper--no
I use air on my Eurika.
Apr 26, 2009 | Vacuums
Vacuum cleaner filters
Sponge filters should be washable. I have found that "FLASH" lemon floor cleaner is by far the best, but washing up detergent will do (far too many bubbles to get rid of for my liking!). I find pouring the detergent onto the sponge and working it in before dunking it in very warm water works best. Despite not being very washable, most paper filters can be washed if you have no other choice and you take care. Just pour on cleaner and then dunk up and down in hot water. Then leave in the airing cupboard for a couple of days to dry. It should get you by until you can find somewhere to buy a new paper filter.
Jan 23, 2009 | Vacuums
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the Hepa filter on this model (*this model uses a vacuum cleaner...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=794479
Generic problem for all Vacuums
Posted by gohornsgo on July 17, 2008
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the HEPA filter on this model (*this model uses a vacuum cleaner bag also).
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to clean the HEPA filter is to take it outside and use a blower over the trash can and blow off the dust and dirt, or use things like an old paint brush and brush it off, or you can vacuum it off with another canister vacuum or shop vac if you have an extra one. For the best filtration is to replace it, there fore the air flow will catch most of the dust and dirt and then you would have to watch how fast it gets dirty and then do the maintenance.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
Vacuums Logo
168 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
