Question about Sony Playstation 3 (PS3) Console
The system shut itself off and when I turn it back on the light goes green, yellow, then red right away. The book says overheating but I do hear the fan run. The system has not been on since yesterday.
    Master:
  • 525 Answers
These symptoms are known as the yellow light of death. Your best bet at this point is to send it in for repair. Sony charges $150 for out of warranty repair as do most repair shops. Good luck...
Posted on Apr 02, 2011
My ps3 shut down in the middle of game play. Then when I tried turning it pack on, this is what happens... The power light flashes until I touch the power button, then it goes solid red. That means it's...
It seems that your unit may have overheated while you were playing that game, that yellow like you are talking about is the 360's Red Ring of Death. Try this, eject the HDD and let it cool off for about 24 hours. Don't put it in the refrigerator or anything, just let it cool off. Tomorrow, pop it back in and make sure there's nothing covering the air vents. Dust, Paper, a Blu-Ray Player, Home Theater Box, a Wii, a 360, anything.
If it's still doing it tomorrow, call SCEA (1-800-345-7669)
Jan 01, 2011 | Sony Playstation 3 (PS3) Console
Hello, My PS3 just keeps turning itself off. I have tried to reset the system but it keeps flashing red and yellow lights and then turns itself off into standby mode? HELP......
Try removing the game inside your disc. then try removing other external hardware and slots and try again. If problem persists it might be a system problem. Please go to the shp from where you bought it and ask them for a replacement.
May 16, 2010 | Sony Playstation 3 (PS3) Console
When you turn the unit on it goes to a green light then beeps twice and goes to a flashing red light?
This is an overheating problem.
Let it sit for about a day and then try it out.
Make sure it has ATLEAST 4 inches of open space all around it and is not near any heat-making devices, it makes enough heat on its own.
Also make sure it's not on carpet.
If it ever starts to immediately shut-off, blink green yellow and then repeating red with 3 beeps, you have the Yellow Light of Death.
This is a console killer.
Repost as a different question if it turns into the YLOD.
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
I was playing a game and it just shut off. It went to a red light on the left side. If I try to turn it on, the left light goes green, then yellow and right back to red and never engages.
If it continues to blink a red light when it turns off, this is known as the yellow light of death (ironic i know). This is caused by the unit overheating causing the solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
Feb 05, 2010 | Sony Playstation 3 (PS3) Console
On switch button turns green and immediatley turns off again. My disc in the beggining stoped spinning eventhough i can here it trying to spin
Can you hear the fan spinning on the inside of the PS2? If the PS2 comes on, loads the disc, then shuts itself off, chances are it is overheating and shuts off to prevent damage. There is a small fan on the inside of the Slim PS2 that keeps it cool.
If you press the reset switch and it goes from red to green and immediately back to red without ever turning on, your motherboard is shot. ESD damage.
Nov 11, 2009 | Sony PlayStation 2 Slimline Console
Tv keeps turning itself off
You most likely either have a faulty power supply or high voltage transformer that is failing. You can test them both with a voltmeter or multi-tester. The capacitors on the newer sets seem to overheat and burn out quickly
Oct 10, 2009 | Televison & Video
60gb ps3 wont start up.
Possibly the very common mother board failure. Slight possibility that the power supply is failed, but the capacitors in either component can be tested with capacitor tester and service manual to test for the faulty component.
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
I cant start up my console
Your system has overheated. The thermal compound has heated and moved away from the CPU/GPU and the heat sync keep the heat from being dissipated via the heat sync. Eventually you will get the YLOD which is the equivalent of the Xbox 360 RROD. This is due to heat sysnc problems. Your CPU and GPU will more than likely need to be reflowed. I got the YLOD on my PS3 around the first of March 09. I also fixed my PS3 in about an hour. I have had no problems since. You can slow the YLOD but i dont believe it can be stopped. It seems it will eventually happen to all PS3's. One tip do not stand the PS3 on its side keep flat. This will help keep the thermal compound from moving as much when it heats up. Also i run a home based computer repair business in southern California. Feel free to email me at dwdpcrepair@gmail.com.
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
PS3 Quit
Alot of the playstation 3 systems are having problems overheating. this would be the cause of the system shutting off. not to much u can do unless u know how to replace the fan or if you bought the warranty. other then that you would have to take it to get fixed or buy a new one. hope this helps sorry if it dont
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
73 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
