Question about Toro Garden
I have a old Toro Rear Bagger 18 lawn mower. The handle and the swiches are broken but the motor etc. works well. The wiring in the handle came apart. Forgetting about the switches, I need to know in general how the wires connect. From the wall plug I have 2 wires. Call them Black-1, and White-1. From the mower, I have 4 wires: White-2, Green-1, Red-1, and Black-2. Can you tell me how they connect? A second question is where would you put the switch(es)? Thank you.
  • 313 Answers
SOURCE: Lawn Hog
give me your fax # i will send 1 for you
Posted on Aug 04, 2008
  • 246 Answers
SOURCE: bought a 2002 toro timecutter 18-52 zero turn lawn
Hello:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, https://lookup3.toro.com/partdex/default.cfm and Select Start Parts Viewer. Now Enter the Model Numbers () and Click Search. Now Select View Assembly Drawings for your Year Model.
At the Bottom of the Page (#6), Use this Link to Locate your Local Toro Dealer who can Order the Manual for you or you can Contact Toro Using the Options at this Site Addy; http://www.toro.com/contact/Homeowner.html .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 24 Answers
SOURCE: bagger problems
I would say is to run the mower at high rpm's and slow the tractor speed down and not take full cuts.
Posted on Aug 23, 2009
  • 15 Answers
SOURCE: Toro lawn mower
You may have overserviced the oil.
Posted on Apr 19, 2010
  • 150 Answers
SOURCE: pull cord wont retract on
Sounds like a spring problem. Remove starter shroud, try pulling it and see if it works. If the spring isn't broke you may have to take another rap on the rope to gain more tension, or spray mechanism with some wd to free it up.
Posted on Sep 28, 2010
PTO wont engage how can you check
PDF]Owners Manual - Mowers Direct
www.mowersdirect.com/manuals/20382OM.pdfSuper Recycler® Lawn Mower. Model No. ... Whenever you need service, genuineToro parts, ... This manual identifies potential hazards and has safety.
You can download the above from google.
You can also check if there is a safety feature keeping the PTO from engaging.
Jul 17, 2015 | Toro Super Recycler Super Bagger Lawn...
Engines dies after 5 seconds
loosen the fuel cap and try running it the vent in the cap could be plugged up
Jun 11, 2012 | Toro Super Recycler Super Bagger Lawn...
Toro lawnmower Wiil not start
Remove carb float bowl. Clean bowl. Observe float bowl screw, look for hole thru bolt, if present use thin wire to clean out. Float should be hanging freely and gas should be flowing, raise float gas should stop. Pinch off gas line or use shut off valve. Remove pin from float, remove float and needle meter. Use thin wire to clean out passage were meter needle is inserted, wire should pass thru to behind choke. Replace float & meter needle. Replace float bowl. Pull rope half way several times. Inspect primer bulb for cracks or leak. Try to start, may take 5 or more pulls to prime.
Jun 04, 2012 | Toro Super Recycler Super Bagger Lawn...
How do I raise and lower the blade
Each wheel has an adjuster on it Usually A is lowest setting and E is highest setting
May 18, 2011 | Toro Super Recycler Super Bagger Lawn...
I have a Toro super recycler model 20017 with a tecumseh motor, model LEV120, spec 361541B has spark and is getting fuel but will not start any suggestions? Have already replaced coil cause previously had...
Make sure that the doggone brass bolt that holds the carb bowl on was cleaned as well. It is the main jet and has tiny holes that get clogged from evaporated fuel/varnish and debris (if no inline fuel filter is used). It has holes on the bottom and the smooth part of the sides...it needs to be clean and shiny! If all is well and the motor is an OHV, then maybe the valves need adjusting.
Sep 14, 2010 | Toro Super Recycler Super Bagger Lawn...
Garden Logo
91 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
