Question about Maytag SkyBox MBV1976A Beverage Dispenser
On my sky box model # mvb1976aab stopped cooling, i replaced the two parts on the compressor with kit # 4387535. compressor runs, but still doesnt cool. How do i know if compressor is ok?There is no way to hook up a set of gauges.
    Guru:
  • 683 Answers
Small line very hot small line cold.
Posted on Apr 03, 2011
My refridge and freezer stop cooling fan is
check the overload relay, see the motor compressor , on side ot its body had a small box where the wiring goes in, open it and check the relay , see if still have continuity or better yet replae.
Oct 31, 2009 | Kenmore Refrigerators
ED5SHEXKQ01 is 7 years old. Stopped cooling. Fan is running.
It could be your compressor trying to kick in. Or it could be your defrost system trying to start or stop. The least expensive thing to start is to replace the start kit on the compressor. Call or email us and we'll be sure to get the right part to you asap. You need to turn it off NOW before you burn the other parts up and don't turn it back on until you install new parts.
Sep 09, 2009 | Refrigerators
Refrigerator and freezer are not cooling. can here it running (clicking) but will not get cold. We think it cools and then shuts off. New house just got keys yesterday. it was running on Tuesday?Spoke to a...
Yes replace the start relay and overload. Part number 4387835 or 4387535 or 8201799. If that doesnt help it then you need a need compressor. Most of those factory relays have a capacitor on them. You need to pay attention to how they are wired up.
Jun 06, 2009 | KitchenAid KSRS25ILSS Side by Side...
NOT COOLING
HI, since the unit still has power, this will rule out any capacitor issues and failed evap/condenser assembly as well. The most likely issue here is that the compressor has failed.
There are many components that will cause this failure and, here is a run down.
COMPRESSOR PARTS
Starter device component
Compressor relay & overload component
PTC Relay
Compressor tank.
If this fridge is a bit up in its age, i would recommend purchasing a new thermostat and, i would also recommend purchasing a complete compressor replacement kit. this kit has every component and part you will need to restore the cooling abilities of your fridge. it will fix this issue.
The compressor kit will cost $262.00 and the thermostat will cost $55.95.
Please rate and god bless:)
Apr 15, 2009 | Refrigerators
Amana refrigerator stopped cooling.
Have you been hearing a clicking noise coming from behind the unit? This is the first indication of a failed compressor relay. Pull the unit out and unplug it. Remove the back cover and go to the compressor. You will find a device on the side of the compressor that has the wires hooked to it. This is the compressor relay and overload. It may be under a black cap. Remove the cap to access it. It may have 2 pieces to it or it may just have the 2 pieces encased in a white and tan box. Remove this box and shake it. If it rattles like gravel in it then it is bad. If it is in 2 pieces then it will have a brown relay. This is the piece that will rattle if bad. The white and black piece with one wire is the overload. They most never go bad. Use this replacement part kit...8201786 and follow the detailed instructions included in the kit. Thanks for the question. Hope this helps.
Apr 11, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Sky box--soda fridge--compresser not running -fan on the inside running
what about the condenser fan.? is it running?...that is the fan near the compressor.
if it is not running, then it could be the thermostat. the part that controls the cooling including the compressor and the condenser fan, please check it.
tnx 4 using fixya,
drcool
Sep 23, 2008 | Maytag Refrigerators
Kitcheraid KSRG22FKBL01 Refer
replace the compressor overload with part numper 4387535
can get it at www.apwagner.com
Jun 23, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Installing new over load relay
The line voltage goes to the overload and the neutral(and capacitor lines if it has one) goes to the relay.
Dec 05, 2007 | Whirlpool GS6NBEXR Side by Side...
Maytag SkyBox MBV1976A Beverage Dispenser Logo
457 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
