Question about Canon ZR200 Mini DV Digital Camcorder
The usb connection broke off and is inside of the camcorder, so i can't view any recorded tapes with no hookup
    Genius:
  • 1,812 Answers
The USB connector can be replaced. This can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Posted on Apr 03, 2011
I have an older camcorder that hasn't been used in a while. When I went to try to view the tapes made on the camera, I just get a blue screen with a white play arrow. The tape is moving inside though. It...
The video drum inside the tape mechanism consists of two sets of heads. One set for recording and one for playback. It's possible the playback heads are damaged, in which case the video drum will need to be replaced. It's also possible the video drum may simply be oxidized in and the camera only needs servicing and the drum deoxidized. I don't reccomend using "cleanning tapes" as they can sometimes do more harm thab good although you try. You might get lucky and this will solve your problem.
Aug 03, 2010 | Sony Handycam CCD-TRV68 Camcorder
Hi I have just inherited my daughters canon mv800i digital video camcorder. It has no instructions with it and I want to use it, plus play tapes she has recorded and save them to disc, can this be done on...
if u can find Corel VideoStudio 12 and downloaded it for free as i did ur all set. it has been the best video editing porgram iv ever used and it works well with the type of camera we have.
the program is pretty self explanatory u shouldnt have any problems using it.
Jul 09, 2010 | Canon MV800i Mini DV Digital Camcorder
I cant seem to be able to transfer my recordings to a DVD recorder on my computer The video recorder is a Sony DCR-TRV22E.My computer is PRYON. PRY-i922vp
If the Computer is having Windows Vista installed on it then it's required to use a compatible i.LINK or Firewire cable to connect the Camcorder to the Computer.
Once the connection is established, you can use Windows Movie Maker to transfer videos from the Camcorder to the computer. Make sure that the Camcorder is set to the "VCR/VTR" or "Play/Edit" mode and the tape is playing in the camcorder before importing the videos to the Computer.
If you're having Windows XP on the Computer and using USB cable to connect the Camcorder to the Computer then it's required to install the USB streaming driver and the USB driver for connection on the Computer before you can establish a successful connection between the Computer and the camcorder for transferring videos.
You can install the USB streaming driver using the supplied Software installation disc.
Nov 07, 2009 | Sony Handycam CCD-TRV67 Camcorder
My camcorder can play old tapes but won't record
Your camcorder Sony DCR-HC20E has bad ccd imager problem and that part will be replaced to have live view to record on tape.
I can provide you ccd imager part number info if you want to repair it by yourself.
CCD Imager replacement in this camcorder requires expertise and fair skills of soldering parts in PCB.
Jul 11, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Broken camcorder 8mm tape
Hi There, You can fix your tape yourself. 1- wind out tape from both sides of cassette. 2- cut both sides to form straight edges. 3- cut a small thin piece of clear scotch tape. 4- from cassette tape, put both sides together with recorded side facing down-- in other words you will be putting the scotch tape on the inside of the recorded tape. 4- line up the two ends and splice them together. - cut the excess scotch tape from the edges. Make sure there is no sticky stuff left there because if there is, it could rip out your video heads. The tape should only be played once and at that time, should be rerecorded to dvd or another media.
Hope this helps, mr cicmo
Jan 12, 2009 | Sony Handycam CCD-TRV68 Camcorder
I would like to convert a VHS tape to DVD. I have (1) the Sony Handycam Digital 8 DCR TRV310, (2) Panasonic VCR, and (3) Macbook Pro with iMovie. I don't know much about the digital camera's ability to...
I think you are expecting camera to covert VCR analog video-audio signal into digital so it can be record in Macbook?
Camcorder will not do this job and you need to hookup VCR with DVD Recorder to burn DVD of VHS tape.
Jan 07, 2009 | Sony Handycam DCR-TRV310 Digital Camcorder
I can record and see it recording but i can not view my recording. At first the tape wouldnt eject but i was online and i went to troubleshoot for the cannon mini dv camcorder zr200 and it told me to tap...
1. Connect the camcorder to a TV and check if you can playsee the tape.
2. Take that tape and check it using another miniDV camcorder.
this way you will know if the issue is within the camcorder or the tape.
If is within the camcorder .. take it to a service dealer and see how much is to fix it. Chances are that is not worth to be fix. A brand new ZR900 is just 200 USD ...
Dec 23, 2008 | Canon ZR200 Mini DV Digital Camcorder
Downloading videos
Use USB cable to connect your device to your computer and you should have a software installed in your computer to be able to capture videos from the tape inside on your camcorder. This software will edit and save what you have been recorded and captured. If any question just ask me. thank you for using fixya, hope that helps you!
CHARCOIS
Oct 17, 2008 | Canon MV650i Mini DV Digital Camcorder
Recording from camera to VCR
1st setup ur VCD with TV and playback it to view on TV. If picture is coming, thats OK.
2nd plug ur camcorder in VCR input and select VCR input according to plug in and monitor the camcorder picture on TV through VCR. If its ok, now u r ready to record the picture from camcorder to VCR.
Jun 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
Connecting analog camcorder to HP Computer
You will need whats called a video capture card on your computer, then a DVD burner also. You can then hookup the audio and video from the camcorder to the computer. Playback a tape into a file and record the file to DVD Good Luck
Apr 06, 2007 | Quasar VM-D51 Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
49 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
