Question about LG Washing Machines
Top load LG turbo drum, WT-R852. alarm "no inlet" Only way I can fix it, is to undo hose from tap and release pressure in hose, then do back up and continue, Problem used to happen only in hot weather, but is now happening every load of washing. Filters appear clean. Happens to both hot and cold inlets randomly
  • 27 Answers
SOURCE: Samsung SW65ASP2
If you are sure there is sufficient water pressure at the hose, then your inlet valve is on the blink....replace it.(the unit where your hose connects onto) Oshie
Posted on Jun 26, 2007
  • 1294 Answers
SOURCE: Miele WT 945 Washer Dryer - Spin not working + Water Inlet/Drain Light Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Your filter of the water inlet valve is accessible outside the machine; it is at the water entry point. Close your faucet & check this out; this gets clogged often.
Hope i am helpful...... Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 25, 2008
Mark Harmer
  • 8 Answers
SOURCE: Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Posted on Sep 21, 2009
odiebugs
  • 949 Answers
SOURCE: the check inlet light flashes. I have cleaned the
If your sure the water way is clear, unplug the unit, plug it back in,
and see if the error is gone, if not, place the water lines into the tub and turn on the water to make sure water is coming into unit, if so the problem lies somewhere else.
Re-post if this didn't help, and say you did this but still have the error.
Good luck, hope it helps.
Posted on Feb 05, 2010
tunde007
  • 2382 Answers
SOURCE: My LG Turbo-Drum Top washing
Hi, this is an Electrical Error. The error code "PE" stands for pressure sensor error. This is typically caused by a malfunctioning sensor switch which needs to be changed.
Posted on Feb 05, 2011
ERROR CODE 1e
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters.
TIP Make sure the water taps are fully open.
Make sure the hoses are not kinked or pinched. (Use caution when moving the washer.)
Clean the inlet filters.
Check another faucet in the house to make sure your household water pressure is adequate
You may try the following link, too http://www.lg.com/us/support/answers/front-control-top-load-washers2013/control-panel
Sep 19, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My fuzzy logic LG washing machine, is no longer spinning or washing the clothes its showing error
Check another faucet in the house to make sure your household water pressure is adequate.
Reference:
May 19, 2015 | LG Washing Machines
LG TURBO DRUM DD WT-R854
my LG Turbodrum DD 8.5 KG WT-R852 have an Error Message (A). What can i do
Oct 25, 2012 | LG Washing Machines
How to slove the pe problem
LG's 'PE' stands for '(water) Pressure Error'.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 15, 2011 | LG WFT1071TP Top Load Washer
LG WT-H800 Fuzzy Logic. Everytimes I turn on the power. "PE" error code will appear. What does it mean & how could I solve the problem.
For LG's 'PE' stands for '(water) Pressure Error'
John C
Aug 30, 2011 | LG WFT1071TP Top Load Washer
What does "PE" error message
LG's 'PE' refers to '(water) Pressure Error'
John C
Jul 18, 2011 | LG WD-16115FD Front Load Washer
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
Doesn't suck up the soap from the tray while washing
Try to open your water tap to full or check the filter in the inlet valve or hose. There seems to be a problem with the water pressure entering the machine.
Oct 30, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
46 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
