Question about Husqvarna 125bvx Hand Held Blower Vac
Ive put the wrong type of petrol in my leafblower and siezed it? How can I repair it?
    Novelist:
  • 111 Answers
With a piston and cylinder. It is probably cheaper to just replace the unit. You can take it to a Husqvarna dealer and see what it would cost to repair. Most shops will give you a free estimate if you tell them what happened.
Posted on Apr 03, 2011
How do I drain Santa Fe fuel tank
Put your key back in your pocket! Don't run the engine ! https://www.mynrma.com.au/blog/2015/03/27/wrong-fuel-woes-how-to-save-on-unwanted-repair-costs/
http://www.motorama.com.au/blog/servicing-tips/how-to-fix-petrol-diesel#.V-Yq_fl97IU
http://www.autofuelfix.com/blog/petrol-in-a-diesel-car-guide-and-videos
Call a mobile car repair service to advise you on emptying car as it can be an ******* to drain the fuel out as where do you get rid of the fuel
Sep 24, 2016 | 2011 Hyundai Santa Fe
HOW TO FIX PETROL MIXER STARTS THEN CUTS OUT
problem will be dirt or water in the carby that is blocking the main jet
overhaul the carby,
check for fuel flow to the carby
Jun 25, 2016 | Belle Group Minimix 150 Gas
I have just bought a 1988 vespa px 125 under the seat there is 2 holes one for the petrol and one that says oil ive put 2 stroke oil in the oil tank and petrol in the petrol tank today i hit 50 and the...
older Vespas without separate Oil-tanks need a premix of 1:50 oil in the gasoline - but yours is an automatic oil-mixer type.
check the oil-level-glass under the seat near the choke.
it must be full of oil - the oil tank can hold about 1 liter of 2-stroke oil. How much oil did you fill in?
Probably the previous owner removed the oil supply tube and filled always an oil-gasoline premix. You better ask him about it. If the tube was removed then there was no oil supplied to your engine and it got stuck and the engine bearings are blown.
Apr 07, 2012 | 2011 Vespa GTS 125
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Ran leafblower without adding 2 cycle oil , it finally shut off but did not sieze. the motor tried to turn over the next day but wont start again.
If you ran it without oil, the piston and/or cylinder is scored so badly it won't build enough compression to fire. A few of these are worth repairing but usually cheaper and easier to buy a new one.
Oct 11, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
I have a echo leafblower pb 1000 and this item was given to me but unsure how much 2 cycle oil mixture is needed for this productI
Mix 2 stoke oil with petrol at 25/1 that is your safest bet. if your still unsure speak to the garden machinery experts in bristol, uk their contact infomation can be found on their website http://www.sullivansgardenmachinery.co.uk
Sep 19, 2010 | Echo Garden
Ihave a second hand 1.6 petrol Suzuki Grand Vitara (no manual) the engine symbol on the dashboard as come on ive checked fluid levels,coolant, water,oil and power steering,what else could be the...
you need take the car to auto zone the put it on computer run diagnotic test it is setting off a code saying something is wrong could cause more problems down road if not repaired break something else
Sep 13, 2010 | Suzuki Grand Vitara Cars & Trucks
I ran my 2005 trx450r low on oil it shut down and kick start wont budge ive been told piston could be siezed or the crank went ive also been told i should replace the crank regardless. i dont know if it...
hi,if you have run the bike low on oil,then there is every chance that you have siezed the motor,at the very least you will need to replace the piston and rings,also it is very likely that the bore has been damaged,that will also need to be repaired(it will be a nikasil coated bore)and they are easy to damage and expensive to repair.the crank will(at the very least)need to be removed and inspected,as siezing a motor will have possibly scored the crankshaft and damaged it,there is no point in putting the engine back together and running it on a damaged crank,as failure will be immenent and you will have to do it all again,sorry about this but it is going to be expensive and it makes oil very cheap insurance by comparison...hope this helps...cheers
Mar 27, 2010 | 2005 Honda CRF 450 R
What lubrication can i put down spark plug holes on petrol engine to release piston on mitsibushi
use liquid wrench penetrating oil or PB blaster. spray a good amount and let it soak overnight. this will help loosen up the piston rings which are probably siezed to the cylinder walls. you will also need to drain and replace the oil if you get the engine to turn over and fire up. good luck!
Oct 29, 2009 | 1999 Mitsubishi Galant
Craftsman leafblower running worse
Check the exahust screen (if fitted) for blockage. or exahust port...If it is clean port and or screen and use correct type/ ratio mix.
Dec 14, 2008 | Craftsman 4 Cycle Blower/Vac
Husqvarna 125bvx Hand Held Blower Vac Logo
105 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
