Question about Samsung Galaxy Tab Tablet PC
Tablet wont power on. Holding power and touching screen for 30 seconds does not work.
  • Anonymous Mar 16, 2014
    Tablet will nit power on...screen is black
  • 20 Answers
Do one thing Turn Off Your Tablet
-> Hold Volume Button and Power button for 3 to 5 Secs -> You will see a screen with android and triangle with exclamation mark -> you will also see 4 lines of writing in blue. -> use volume buttons to navigate to 3rd option, use home to select it ( warning this will erase your system data if need please take backup) (memory card is not affected) -> now navigate to 1st option saying " reboot to system" use home key to select it.
I hope this will fix things
Posted on Apr 04, 2011
How do i fix my proscan tablet that is stuck on android screen
Try a power reset by pressing the power button for 30 seconds with your device unplugged, then plug in your device and leave it on the charger for a few minutes, then press the power button again for 30 seconds while plugged in.
Sep 30, 2016 | Tablets & eReaders
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
Stuck on home screen just shows the android writing across the screen, how do I fix?
u don't mention the make check to c if its got a reset button if not look for a little hole with reset on it stick a paper clip in it ??? if there is no reset try holding the power button down for 30 seconds or more if this wont work try holding down power button & the volume button both at the same time it might reset if not it could b faulty good luck
Jul 26, 2015 | Tablets & eReaders
I need to know how to factory reset my tablet. Somehow the touch screen messed up and when I touch the screen it clicks a different spot then where I touched.
Maybe a reboot will fix the problem. Some, but not all, can be rebooted by holding the start button in for 10 seconds. Wait a further 30 seconds or so and restart as normal. Once fired up the problem may be resolved. Good luck.
Jul 25, 2015 | Tablets & eReaders
How do i fix my tablet
Probably have to replace the screen. Try holding in on power button for 30 seconds. The remove battery if first suggestion fails to work. Then press and hold power button for 30 seconds and reinstall battery and push power button. Then try holding for 30 seconds and see if it turns on. Also check battery and make sure it locks in securely.
Oct 20, 2014 | Samsung Galaxy Tab 2
Why wont my proscan android tablet turn on ?
If you haven't done so already, try holding the power button down for a long time (30 seconds+) when you switch it on. If no success, try again but hold down the power button *and* the volume-up button when you switch on.
Aug 10, 2014 | Proscan 7-Inch Android Internet Tablet,...
MY touch screen wont work for some reason so now it wont work
I suggest you to perform a hard reset as sometimes this may be due to a software glitches chances are rare though but still you can give it try. Else you need to replace the touch panel of your table which I suggest you should not do on your own rather take it to a hardware shop. Hard reset in most of the android tablets is usually performed by turning off the tab and pressing power button while holding the volume down key.
Sep 26, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
My acer iconia android tablet refuses to startup
Perform a Factory Data Reset of Acer ICONIA
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet.
Aug 24, 2013 | Acer ICONIA Tab W500PC52G03iss
Emerson tablet
Hold the power button down for about 8 seconds to force it off. Hold it till screen goes dark. Don't release if "power Off" dialogue pops up. Keep holding it to force off.
Apr 16, 2013 | Tablets & eReaders
Touchpad wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 25, 2012 | HP Touch Pad 16GB Internet Tablet
Samsung Galaxy Tab Tablet PC Logo
861 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
