Question about LG GCC4522B CD-RW/DVD-ROM Combo Drive
Lg dvd rom gcc 4522b is not reading dvd - LG GCC4522B CD-RW/DVD-ROM Combo Drive
  • LG Master
  • 27,725 Answers
Make sure that the dvd rom is getting enough power test all leads that are attached to the dvd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 03, 2011
My LG GCC-4522B CDRW/DVD ROM has got problem i cannot read any DVD but it can read VCD or cd-rw can u help my solve tis problem ?
This is due to a weak lens
Sometimes this type of problem occours due to excessive use of the drive in burning cd/dvd
Trying some leans cleaner may solve your problem
Feb 26, 2011 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
I need to install my HL-DT-ST-RW/DVD GCC-4522B driver because my dvd disc not run. THANKS.
In Summary; I have a Dell Dimension 8100 desktop computer. I only have a CD-ROM drive. The CD drive broke, so I bought and installed a CD/RW- DVD Combo Drive (Model # GCC-4522B). I need to know where to set the jumper on the back. The options are CS, SL, or MA. Currently is set to SL but it does not work. I do not get the drive symbol to display under My Computer icon. I thought it was jut plug in and play. Need help if there is something else I need to do. Any response is very much aprreciated. Thank You!
Mar 08, 2009 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
Not reading dvd combo drive
HL-DT-ST RW/DVD GCC-4522B
h!, above is the model type of my combo drive dvd. It does not work anymore, it only reads a cd format but not dvd..can you pls help me with this..my personal email address hpbirco@yahoo.com pls send me ur answer to my problem..tnx
Sep 03, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
DVD not getting detected
Hi, i have LG GCC4522B CD-RW/DVD-ROM Combo Drive and my problem is that i could open & play CDs. However when i insert DVD the drive doesn't detect the DVD and it shows no DVD in drive or blank. I checked the region setting which is 1. Is it the problem of region setting if so is there any solution for this. Expecting your valuable solution in this regard.
Thanks
Moses
Aug 30, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Cd reading problem
The answer on the LG-site (mailcontact): Go to your dealer.
I think that a new one is cheaper than repairing my combodrive ( 2 yrs old).
P.S. : I'am the guest posted on nov 04
Apr 16, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Problem in running dvds
are you sure it reads dvd's ? If it does it should have a dvd logo.
If thats not it Laser may not be working correctly and you will probably need to replace disc drive.
nowadays you can find them real cheap and are easy to install.
Feb 24, 2008 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
Only computer show cd rom can't work
You need to update the driver in control panel. Then it may see it or you might
Sep 02, 2007 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
LG GCC4522B CD-RW/DVD-ROM Combo Drive Logo
95 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
