Question about Behringer RX1202FX Ultra Low Noise Design 12 Input microphone/Line Rack Mixer
Low freguency rumble in my behringer 1202fx. problem goes away sometimes when i switch unit of and on but no effects
  • Behringer Master
  • 5,603 Answers
You are somehow feeding back. Maybe the effects are on with an echo setting. First thing: Make sure ALL interconnected equipment are powered from the same receptacle or source. This includes amps and speakers and any other devices that are powered. Make sure ALL interconnects use BALANCED interconnect cables either TRS or XLR type. First thing is to eliminate ground loops by the above proceedure. Note the pros run power back alongside their snake from teh stage. Using multiple outlets in a building to power equipment puts equipment at risk and picks up noise due to ground bounce.
Posted on Apr 03, 2011
I bought a Xenyx 1202fx roughly 9 months ago. I plugged it in following the instructions of desk to pack first, then pack to mains, but the LED display didn't show. I've heard that there's no...
If the blue power light does not light up then there is a problem with the unit or power supply. As it is less than a year from purchase I would advise returning it to the shop.
Sep 15, 2011 | Behringer Xenyx 1202fx Mixer 12 Input 2...
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
I have a Behringer 1202fx and I'm going to use it with a pair of Harbinger APS15. The line inputs on the APS15 are unballanced R&L RCA and XLR. The Behringer 1202fx mains are 1/4" unballanced...
Personally I would run the RCA outputs to the RCA in on the APS.
If you insist on using XLR from the APS to the board (like through a snake etc) I would higly recommend using XLR to 1/4" adapters. These things have wonderful little transformers in them (yes, wire wound transformers) that do the 1/4" to XLR conversion really nicely so that you can run your signal through the snake or just so that you don't get the hum and distortion that can be associated with unbalanced signal transfer.
You want a HI-Z unbalanced to LO-Z balanced adapter.
Not always easy to find, but if you absolutely cannot locate any, I have a couple in stock.
I suggest you look around though, because mine aren't cheap!
Feb 27, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
What imput do i use for on/off footswitch
Sorry, this device does NOT have a footswitch input to control the effects processor. I would suggest using an external effects unit that does have a foot switch input using the FX send and Aux returns of this unit.
Jan 30, 2011 | Behringer Rx 1202fx 12 Channel Line and...
I am having problems with the effects. I cannot get any effect from it now. Please, help!
Make sure that BOTH the FX gain at each channel you want the FX on AND the "FX to Main" gain are turned up. Also when you select an effect push in the selection knob to activate the selection.
Jan 21, 2011 | Behringer Rx 1202fx 12 Channel Line and...
An index of 1202 effects on mixer lost list
Most Behringer effects are done with the same DSP unit. If you can find the lst for one, it will likely be the same for your unit.
My PMP5000 has the list right on the face. I don't know how to capture the list but I might be able to photo it.
I have searched and it doesn't seem like there is any documentation readily available.
Mar 06, 2010 | Behringer Rx 1202fx 12 Channel Line and...
How do i hook 1202fx to computer?
just connect a baby plug to rca from the pc to the mixer respectively
Feb 14, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Behringer RX1202FX Ultra Low Noise Design 12 Input microphone/Line Rack Mixer Logo
74 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
