The electricity went off to my printer and it hasn't worked since. I have tried turning it on and off. I have tried resetting the ing cartriges . I have tried unplugging , waiting and replugging. Nothing worked. My printer is not a year old
  • Office Equip... Master
  • 5,473 Answers
Which brand/model of printer do you have? Check the warranty for the printer and contacting the manufacturer, if it is under warranty.
First though what type of power cord does the printer have? If there is a power module (brick), disconnect the cord from both the printer, the wall outlet and separate the cord from the module. Wait a minute and then plug the cord into the module and then into the wall outlet. If it has an LED, is that LED lit? (Check the printer itself or the module and find out what power should be getting to the printer. If you have a multi-meter, check if the cord is getting the correct power level.) Try another power cord if you have one that matches the connection and the voltage output (for a power module).
Some printers have a soldered-in fuse and it should be handled as a warranty repair when the printer is under a year old.
I hope this helps.
(I'm currently waiting for a return shipping label for a similar printer issue. HP gave a credit for a new printer instead of sending a refurbished unit. I didn't have a spare power cord but did have 30 V at the printer side of the power module's cord. This was at the specifications for the unit. This is the first HP printer I've ever had fail within a year. Previously the ink jet failed after 9 years of use.)
Posted on Apr 02, 2011
Motherboard problem?
In general it costs more to repair a printer than to replace it. Spares are not easy to get. Sorry.
Feb 23, 2014 | HP Officejet 6310 All-In-One InkJet...
Not printing correctly. Says to align cartriges. After aligning cartriges, it stills prints incorrectly no mater how many times I align cartriges.
Clean the ink cartrige and the cartrige carrier with lukewarm water or alcohol on a cotton cloth and then install the cartridge. Even if that does not work then you will have to reset the printer for which turn off the printer and then press and hold power and start buttons for 10-15sec and then release.. Then try it again.
Oct 21, 2010 | Dell 964 All-In-One InkJet Printer
My dell 962 printer was working fine. Then the next time I went to use it, the malfunction light was blinking and I had the message "right cartridge incorrect". I took it out and back in, unplugged and the...
You can try a new cartrige...and I would check to see if it's under warrenty. And there also a proccess for resetting the unit / master reset...it's in your product quide.
Thanks
Feb 20, 2010 | Dell 962 Photo All-In-One InkJet Printer
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Ditto!!!
TRY turn ing it off then back on using the power button, if the problem persists then you could try the following procedure:
1 .Unplug the printer from the electrical outlet
2. Press and hold the # and 3 keys on the printer
3.Plug the printer in while still holding the buttons
If that still doesn't fix it then full service .hope this helps
Aug 30, 2009 | HP Officejet 6310 All-In-One InkJet...
Printer Cartrige Problem [Tri-Color]
if the printer queue is empty and you have turned both comp and printer to off it should reset.
Frpm your explanation it sounds like your color cartridge has a problem Tricolor red,blue, yellow maybe one is empty the black is a separate cartridge
Jun 21, 2009 | HP J4680 Office Jet All-In-One Printer
Printer does not recognize a full ink cartrige. Problem has responded to removing and then replacing the cartrige in the past, but that no longer works.
try to unplug your printer while it is in ON state ...it reset all your settings and after that it can recognizes your full cartridges..
May 17, 2009 | Canon Office Equipment & Supplies
I haven't used the printer in a while (about 6 months) then last week I turned it on and tried to use it. Went to print a test page and it went through the process but nothing came out on the paper. I...
Take out the cartriges and hold one at a time between your forefinger and thumb tightly. Hit your wrists together and see if ink comes out the bottom of the cartrige. Be careful not to mess ink on your clothes or carpet etc. This sharp "shock" will bleed the cartrige and hopefully the cartrige will work. Clean all messed ink from any contacts and the jet area of the cartrige before inserting back into the plotter.
Dec 14, 2008 | HP DesignJet 750c plus InkJet Printer
Wrong cartridge
Nice Printer.
First of all, see if its reading on the computer, if not, try and hold the power on the printer untill it shuts off, and then turn it back on again. Also, you might want to check the troubeshooting section if you have the manual
If none of the above works, try getting a replacement cartrige. if the connectors on the cartrige get messed up, the printer may not read the cartrige properly. Make sure the printer's connection to the cartirdge is ok too. If you know someone who has the same printer, try the "ERROR" cartrige in that printer. if it works, then your printer needs to get fixed. If it doesn't work, get a new cartrige and all should be fine. Don't get the cartrige refilled if it doesn't read in a nother printer, you need to replace the cartrige!
Jul 17, 2008 | Computers & Internet
Paper Jammed Message
try turning you printer off and unpluging it from Electrecity.
after that cancell all the printing jobs at your computer.
and last do a double check on the printer to make sure that there are no more paper left-overs into the printer.
try turning the printer on (after pluging to Electricity) and see what happen.
Mar 21, 2008 | Canon PIXMA MP170 All-In-One InkJet...
73 people viewed this question
k24674
jasbo
jasbo
