Question about Toshiba Computers & Internet
My screen won't light up. When I start up, I see a very dim, reddish Toshiba start logo, and although everything else loads and starts up, the screen remains black. If I light the screen from the side with a flashlight, I can see the desktop and any programs I open. I've checked the display settings and I'm fairly sure they're all OK, and I've checked to make sure the lid/case latch switch is working and not stuck. What now? Plz. Help, Thank You! INFO: 1. Toshiba Satellite M45 / WinXP HomeEd / SP3 / 2. DISPLAY: Name: Mobile Intel(R) 915GM/GMS,910GML Express Chipset Family 3. PNP DEVICE ID: PCI\VEN_8086&DEV_2592&SUBSYS_FF101179&REV_03\3&B1BFB68&0&10 4. ADAPTER TYPE: Mobile Intel(R) 915GM/GMS,910GML Express Chipset Controller, Intel Corporation compatible 5. DRIVER: c:\windows\system32\drivers\ialmnt5.sys (6.14.10.3929, 734.47 KB (752,093 bytes), 10/8/2004 10:54 AM)
  • Eve Erace Apr 03, 2011
    I'm pretty tech saavy and not afraid to dig in to do repairs. Where should I look for info on how to locate the inverter to check the connections, and/or replace it.
  • 61 Answers
Hi...
Its either a broken/loose wire on your invertor,or your inverter may have given up the ghost...they are easy enough to replace and quite cheap in ebay....just put the make and model of your laptop on ebay...and there should be plenty on there for anywhere between £10-30...and it,s about 30 min-60 min job depending on your experience
Posted on Apr 03, 2011
Testimonial: "Thanks, this tells me at least where to start."
  • anthony_grac Apr 03, 2011
    Your inverter is located behind the screen,should be plugged into the back of the screen..google your laptop specs and technical
  • Eve Erace Apr 04, 2011
    Thanks a bunch Anthony! You've been a great help!
My laptop is lit up but cant go any further
Wdk, Try starting up in safe mode and use system restore to go back to an earlier date when PC ran OK, an update or virus may have corrupted the start up. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Windows is loading files then blank screen
http://ccm.net/forum/affich-108275-toshiba-laptop-cannot-reach-login-screen
My Toshiba satellite cannot load anything at all Windows 8 and Windows 8 1
http://forums.toshiba.com/t5/Windows-7/Windows-7-won-t-start-black-screen/td-p/157700
Aug 27, 2016 | Toshiba Satellite Computers & Internet
Black screen at startup
What changes have YOU made to your DELL? This can be hardware or software related, so please let us know if you have changed anything prior to this problem.
Nov 15, 2013 | Dell Inspiron 1525 Notebook
My Laptop won't fully start/blacks out/won't recover
You are lucky that this issue is operating system based from what it seems, try to work the recovery option, let it be that way for hours. It will move at some point.
Did you have a AV installed? If not it is crucial to have an anti-virus software installed on PC.
If all the efforts appear fruitless, contact Samsung; it could be a hardware issue as well... although they are less frequently observed.
May 29, 2013 | Samsung RV511A01 Notebook
Toshiba Sattelite PRO L300 telling me checking file system C one of disks needs to be checked However it then says an error has occured and won't leave this screen !
Press F8 and choose command prompt.You may have to use a boot disc if you can't get c prompt.
Type cmd ENTER. From the Command Prompt type chkdsk /r/f ENTER. R and F are redundant for repair and fix, but does not hurt.
Oct 29, 2012 | Toshiba Satellite Pro L300 Notebook
My 2004 f150 wont start. i drove it to the store and everything worked fine. when i came out of the store, the truck won't start. when i turn the key nothing happens. i can hear a clicking noise coming...
I would check your battery. I would also look for loose grounds. The clicking you hear is your fuel pump turning on. I would check your battery voltage and, have the battery load tested.
Sep 04, 2011 | 2004 Ford F150
No Screen display on tecra m3 laptop
if you go into safe mode (F8) on boot-up, does the graphics show up?? If so, it's the graphics board/chip on the MB. I have one and have the same problem - no amount of loading drivers, re-install BIOS, etc. would help. sometimes it works, but most times when you start up, shows the Toshiba logo, and once windows starts, goes to a black screen.
Oct 02, 2009 | Toshiba (K000823110) Motherboard
Replaced bulb - no picture - blue dim light
Ur CRT need a rejuvenation,it a messy job.
It cost u the big screen repair shop about $300 dallors.
Sep 02, 2009 | Televison & Video
Toshiba a105 screen goes black then stops booting up when startng
try access the safe mode.. then remove the some virus or.. if you installed same latest program remove it then start again...
it you dont installed any program check the control pannel,, add and remove program remove all programe not neccesary...
Jun 08, 2009 | Toshiba Satellite A105 Notebook
Excellent picture for a several hours, then gradually dims.
if this is a old unit the there is serious problem with the display.
check how many times the light blinks and get back to us.
Feb 08, 2009 | Toshiba TP43H60 43" Television
Computers & Internet Logo
325 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
