Question about Balboa Instruments Duplex Digital Panel 2 Pump
We have a 2004 Balboa series spa and the breaker keeps tripping what could cause this? Everything has been working fine.
    Scholar:
  • 46 Answers
Understand that this information is beingprovided as-is and without warranty or guarantee. As with all electricalcomponents and devices, all work should be performed by a licensed spa or pooltechnician. Serious injury or death can occur if a component is improperlyrepaired or installed.
There are several reasons the breaker can trip. It could bea bad pump, bad heater, GFCI or wiring issue.... Typically unplugging eachcomponent will help isolate which component is causing the trip. It is rare fora board to cause a breaker trip, so if all components (including both legs ofthe heater) are disconnected and the breaker continues to trip then you move onto wiring or the GFCI.
You can find answers to common spa or bath problems online at http://www.balboadirect.com/support.aspx
Posted on Sep 12, 2011
What runs on the .3amp fuse?
look on inside cover of control unit it has a schematic
Jul 04, 2014 | Balboa Instruments Pool & Spa
Balboa vs510s not heating
questions first:
is the heat indicator lighted up on the topside panel?
Is is tripping the breaker shortly after you turn the breaker on?
Is the tub running but not heating?
Rod
www.uspartscenter.com
888-521-6183
Jan 31, 2013 | Balboa Instruments Pool & Spa
I have a balboa board #55098 and nothing works. I have disconnected everything and then tried powering up and it only clicks until the breaker trips any suggestions?
As with any troubleshooting over the Internet, this is like giving a haircut over the phone. So, that being said, this problem could be any number of reasons.
Here are some things you should have a spa technician look at (not in any specific order):
  • Power connections
  • Relay
  • Whether the transformer is seated properly
  • Whether there are loose wires
Disconnected all the components and see if it still does the same thing. If not, then one by one, reconnect the components until you isolate the problem. If the problem persists, then you might have a larger problem like a blown circuit board, etc.
Hope that helps!
Jun 17, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
I have a Balboa Instrument Panel for my Spa. Model # M51500 part #54493-200701300092. My question is the main 50 amp breaker keeps tripping not allowing power to the spa. There is no blown fuses that I...
This is most likely a heater issue. The technician needs todisconnect both heater leads to see if the breaker will hold. This will help you determine where theelectrical problem is occurring and why it is tripping.
You can find answers to common spa orbath problems online at http://www.balboadirect.com/support.aspx Hope that helps!
Jun 01, 2011 | Balboa Instruments Duplex Digital Panel 2...
Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
May 08, 2010 | Pool & Spa
Gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
Jun 22, 2009 | Balboa Instruments Duplex Digital Panel 2...
I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
Jun 07, 2009 | Balboa Instruments Duplex Digital Panel 2...
Balboa Instruments Duplex Digital Panel 2 Pump Logo
497 people viewed this question
Top Balboa Instruments Garden Experts
Craig Butler
Craig Butler
Delage guy
Delage guy
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
