Question about Tatung V27DMBX 27 in. LCD Television
MODEL V27DMBX- NO POWER, WON'T TURN ON. - Tatung V27DMBX 27 in. LCD Television
  • 1,238 Answers
Good day sir
the problem of your TV is on the power supply
I teach you some D.I.Y.tips and troubleshooting for your problem
I give it to you step by step
first remove the cover of your TV by unscrew it at the back
secondly after that the power supply reveal it is the one that have a ac input from your ac cord or supply
thirdly,check your fuse if busted,replace fuse if busted and also check the regulator transistor if shorted then replace also
after that,also looking for bulging top capacitor/leak replace it in same type and rating voltage/microfarad
and finally after same troubleshooting..test it by power it on again
thank you
Posted on Apr 03, 2011
  • 4 more comments
  • jones9251 Apr 03, 2011
    Thanks for the help. I didn't see any fuses or bulging or busted caps. Do you know where I can get a componet diagram of the power supply board?
  • bonifacio gomez
    bonifacio gomez Apr 07, 2011
    I'm sorry sir,,if my solution is not fix your problem it means that's not for D.I.Y...the trouble of your power supply is major so even you got a diagram I'm not sure if you fix that
    I search for diagram of your power supply but I found nothing...
    as a technician I suggest to you sir to buy a new power supply because sometimes new unit is more cheaper than repair specially when you give it to the technician..and its not 100% sure
    this suggestion is base on my own experience as a technician
    thank you
  • jones9251 Apr 08, 2011
    Ok, thanks. I have not been able to find the power supply (part #6693006610). I tried shopjummy.com and it is not in stock. Do you know of any other suppliers?
  • bonifacio gomez
    bonifacio gomez Apr 09, 2011
    http://www.1sourcecomponents.com/search/...
    try to contact this to assist you sir
  • bonifacio gomez
    your part is cannot find on their database but they can find for you just contact...
  • jones9251 Apr 09, 2011
    Thanks for the info. I called 1sourcecomponents, they only sell to companies not individuals.
Panasonix tx L32S20BA
Check and replace its main power regulator board. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jun 04, 2013 | iLO V27DMBX Television
Ilo HD TV won't turn on
try another power cable (usually these tvs use the same power cords as a number of other electronics, such as desktop computers, etc) - if that doesn't work, try another power outlet - Also, try powering the tv on with the power cord out - this clears the static electricity off the system board, and helps w/ power issues sometimes - if still no power, then you can contact Wal Mart's customer service (since iLo is their in-house brand) @ 1-800-925-6278 to see if it's still under warranty or if they can put you in touch w/ an onsite technician.
Good luck - hope this helps!
Sep 13, 2009 | iLO V27DMBX Television
5 min to turn on with a electric burning smell
Probably the power supply board has leaky capacitor's.
They can smell bad. if you could see the PSB the caps would be puffed at the top and leaking oil. It wont be long and the set will go out " lose all power"
Mar 05, 2009 | iLO V27DMBX Television
Will not power on
If you know how, replace all the capacitors that look puffed up or leaking. If this is moore than you can do check Ebay I see a lot of boards for sale cheap there. Enter model and Power supply to your search
Mar 02, 2009 | iLO V27DMBX Television
1lo-26hd tv
Try to buy a universal remote control. I reccomend a philips.
Feb 19, 2008 | iLO V27DMBX Television
Ilo tv
These set have a poorly built power supply, several capacitor will dry out and fail this shuts down the set, some techs can repair the power supply but replacment is the best way
Feb 13, 2008 | iLO V27DMBX Television
I had the same problem. One repair shop said that they could not get parts. With $50 down the drain I took it to another guy who had the power board replaced in one week (for $200). So it can be done.
Jan 07, 2008 | Tatung V27DMBX 27 in. LCD Television
No power
Do what I am going to do. Take it back. Mine is only a day old.
Jul 31, 2007 | iLO V27DMBX Television
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Ilo 42 in plasma
This must be a Samsung controller inside. Samsung controller have trouble finding if signal is ntsc or pal when tv is turn on before the source. If this is the case, just turn off the tv, start the cablebox and power on the tv again.
Jan 16, 2007 | iLO V27DMBX Television
Tatung V27DMBX 27 in. LCD Television Logo
178 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Josh Whitehead
Josh Whitehead
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
