Question about Cameras
I have the above camera and am wanting to take it abroad. I have an 86B SDHC memory card which I have always used with it and yet, today, when I checked everything was working and turned camera on, it said 'Pictures will be recorded to in built memory'. I have never had this problem before and am going on hol on Tues so I need this fixing. Please help!
  • rebeccahasla Apr 03, 2011
    I have already tried this solution and it made no difference. What is troubling me is that the memory card works in another camera (a far less better one) but not the one I have always used it in. Even with the memory card and internal memory wiped, it still comes up with the same message.
  • Cameras Master
  • 6,771 Answers
If the camera was used once without the card it will cause problems, remove the SD card from the camera, go to menu and locate "format" follow the prompt to erase all pictures in the internal memory, when that is done replace the memory card back in the camera for normal operation.
Posted on Apr 03, 2011
  • John Cunningham Apr 03, 2011
    This solution has never failed until now, the only other idea that I can think of is remove the rechargeable battery and SD card for 60 seconds to reset the processor ic in the camera, if this fails there is a problem in the systems control board which controls vital areas of the digital camera and consideration should be given in replacement.
What is the maximum size sd card (Gigabites)?
speed class choices.
about compatibility with host devices before choosing your card, it is important that you understand how to use your memory card to it greatest ability. sdxc memory cards and devices (digital cameras, video cameras, laptops, etc.) are now available. learn how to use your new sdxc memory card to optimize its performance.
confirm compatibility before inserting your sdxc memory card, confirm the device is compatible with the sdxc standard by locating an sdxc logo on the device or referring to the device's user manual or manufacturer information.
understanding backwards compatibility
  • sdxc memory cards must only be used with sdxc devices.
  • sdxc devices can use sd memory cards, sdhc memory cards and sdxc memory cards.
  • sdhc memory cards can be used with sdhc devices and sdxc devices.
  • sdhc devices can use both sd memory cards and sdhc memory cards.
  • sd devices can only use sd memory cards.
http://www.tomshardware.com/charts/memory-cards,39.html
the link above has several chart on sd cards.
Jan 20, 2015 | Cameras
I get the message 'protected card' Next trick?
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Dec 10, 2011 | FUJIFILM HS20 EXR Digital Camera
No matter what card we put in the camera, it always read locked and will not take pictures. please help!!
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Aug 16, 2011 | Canon PowerShot A650 IS Digital Camera
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
I have a kodak easy share C315 the message keeps telling me to reformat the memory card, I say ok and then it gives me an error. I tried to reformat in the computer but I don;t know how. The memory card is...
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manual for the camera was written.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible. If the card you are trying to format is above 2GB, it will be an SDHC card.
Nov 30, 2010 | Kodak EasyShare C315 Digital Camera
4gb card is not recognized
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible. A 4GB SD card is actually SDHC.
Nov 27, 2010 | HP Photosmart 812 Digital Camera
I have a Jazz HDV149 Digital Camcorder. when you turn it on and insert a memory card it asks you to format it. Yes is automatically highlighted but when you hit the center button to format nothing...
Try changing it to "No". I always have trouble figuring out whether highlighted means light or dark on these menus.
If it still doesn't format, maybe you are using a memory card with too high a capacity. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manual for the camera was written.
Nov 24, 2010 | Jazz Cameras
I have one canon camera, presently i am using sandisk 1GB memory card without any hassel. recently i purchased one Sandisk 4GB memory card. after putting this new memory card into the camera, I m always...
A 4GB memory card will be an SDHC type. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 22, 2010 | Cameras
I have a Canon SD400 Powershot digital camera. It
First, make sure your camera can accept SDHC cards. If the camera says the card is locked, move the slide switch on the side of the card.
Jun 13, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Optio E10: memory card error
if the cards work ok on something else then there's a issue within camera it could be the actual sd connector within the camera ? doess the camera support that size ? Optio E10 supports upto 1GB SD Card http://www.pentaxcanada.ca/pdf/o_manuals/om_OPTIOE10_e.pdf it might not work with the high speed sd cards ? Regards
Jun 15, 2009 | Pentax Optio E10 Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
