Question about Rheem Pool & Spa
Rheem P-M407A-EN-C Pool/Spa heater does not start. I get the CFH then SPK but the unit just stays in SPK mode and will not turn on. I can hear the sparking cycles. The unit is about a year old and woked great last season. This is the first time I tried it this year.
  • rickspool
    rickspool Apr 04, 2011
    Is the gas valve open ?
    Top Expert:
  • Rheem Master
  • 8,686 Answers
If sparking then check gas
Posted on Oct 11, 2017
johnsonr1
  • 91 Answers
SOURCE: Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Posted on Aug 22, 2009
So now we know what it stands for. Now how do we call for heat? Can we do this ourselves?
Posted on May 25, 2010
  • 760 Answers
SOURCE: I just purchased a home
They have good listings on their web site.
http://www.rheem.com/product.aspx?id=8B064EC5-B708-4821-9F2B-DEF3A2243F90
That link should be to your model. When you click on the link for your manual (installation instructions)l, if it doesn't download. Right click on the link, and select download
So what is the problem?
Posted on Aug 12, 2010
tbreeze47
  • 3083 Answers
SOURCE: I have a Raypack pool
Have you tried using a fine emory cloth to clean the ignition wire terminal? Sometimes oxidation builds up on them, and they play heck making contact. CFH is call for heat, and SPK is spark. Clean or replace the ignition wire good and see what happens. The clicking sound is probably the electronic ignition trying to spark.
Looked on the net, but couldn't find these codes, and noone reported any problems. It could be a temperature sensor- that is the cheapest thing to try first. If that doesn't fix it, it could be a faulty ignition unit.
Here is a good web blog of these systems, and may assist you:
http://blog.poolcenter.com/article.asp?articleid=6050
Good luck, thanks for using FixYa, and hope this helps.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 05, 2010
  • 2187 Answers
SOURCE: Hi, The pilot won't light
I am thinking it could be the relay. The relay directs the power to the device. In most devices it is the one that makes the 'clicking' sound.
Posted on Apr 10, 2011
Why do I get CFH but then no SPK?
CFH = Call For Heat
SPK = Ignitor is Sparking - attempting to ignite raw fuel
In a lot of cases, Pressure Switch opens up, CFH , is cancelled and therefor no ignition sequence.
try cleaning filter really good. If cartridge, may be time for an overnight soak.
May 21, 2015 | Raypak RP2100 DIGITAL POOL HEATER R265
Why does pool heater read SPK and won't light?
Sounds like your ignitor is shot. You may have to replace it.
Jul 24, 2014 | Rheem Water Heaters
Heater takes a long time to fire up.
There is a flow switch if that's not working. same problem needs to be tested Gas valve solinoid could cause this Igniter could cause this problem Gas pressure regulator wrong pressure should be about 2.7KPA LPG Gas valve should be set to about 2.6 KPA LPG
Mar 28, 2013 | Rheem M206A 206K BTU Pool and Spa Propane...
When we tried to light the heater the CFH shows, then I get a SPK which stays on for aroound 1 minute, then I get a LO. The heater never lites.
The CFH is a Call For Heat.
The SPK tells you that it is creating a spark for ignition.
The LO tells me that you are on propane.
The fact that it doesnt light tells me that either the ignitor is not sparking, or that there is no gas, or an incorrect gas supply.
If this unit is installed with flexible gas line, replace this with rigid black pipe or a larger flex line.
Oct 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Pool & Spa Logo
537 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
