Question about LG Heating & Cooling
While running airconditioner water spits out with cold air. Does not happen with heat.
  • 1,420 Answers
It could because the condensate pan is not draining and when on AC, the blower is faster. Try running the heat on high fan. take a shop vac and attach it to the end of the condensate drain to remove any debris stuck in drain line.
Posted on Apr 02, 2011
My portable airconditioner,dimplex dac 3400, the cool function is exactly like the fan function, It doesn't blow cold air??? Do u ever need to regas this machine at any time???
Check the condensor coil to see if it is stopped up. The duct that you run outside to vent the heat that is being removed is attached to it. Does that duct move air at all or a good amount of air?? If coil is stopped up it will restrict air. Is the compressor running? If the coil is stopped up it is likely to overheat the compressor or the compressor start components may of failed. See if you can tell if it is running. It could be a bad compressor. Typically small systems issues do not have problems with freon leaks and you should never have to add freon unless you have a leak. Is there a filter on it check to see if it is stopped up. If it has ran with a dirty filter check the cold evaporator coil to see if it is stopped up. I haven't see. That exact machine but these are basic things to look for.
Dec 10, 2015 | Heating & Cooling
Water spitting out of the hot/cold air vent under driver side seat. I have not run the air conditioner for at least 4-5 months but when I turn on heat full blast to the floor vents a lot of water is...
under the wiper arms is a big cover ,lift the bonnet and look at the back behind the firewall and where the wiper motor is and either side of the vehicle is a well and in the bottom is a drain hole ,look and find then make sure these holes are clear so any water can run out
Mar 12, 2015 | 2004 Volvo S40
I just replace a hose on my jeep larado 4.0 and now its running hot, no water in oil, no sighs of any enteral damage, just getting hot, over heating
check that you do not have an air lock...while the engine is running check the hoses to see if one is cold, run the engine with the header bottle cap off and if one of the hoses has a bleed nozzle then open it until you have continuous water running and not spitting.
Do not put cold water in a hot engine though, it can blow the head gasket.
Jan 15, 2013 | 1996 Jeep Grand Cherokee
The heater is blowing cold air
Coolant system is a closed system. If you are loosing water there is definately a leak somewhere. Check all hoses after filling the system and letting it run until it's warm. Be careful when checking most systems have the water at 185-210 degrees once the vehicle is warmed up. Also check the Heater Control Valve. It allows hot water to travel to the heater core when you set the ac controls to "heat". Could be bad and leaking there. But bad hoses are the most likely culprit. Only takes a pinhole.
Jan 12, 2013 | Rover 75 Cars & Trucks
GE Airconditioner is leaking water from inside
You could try drilling a hole in drain pan so it drains outside.
Aug 23, 2012 | GE Heating & Cooling
My unit is making a loud noise and is spitting water out with the cool air
i have had units turned too cold and ice forms on coils. shut unit down and take it out of window. turn /tilt and when all water runs out, re install and turn back on to a Higher , less cold setting.
Jul 29, 2012 | Hampton Bay HBLG5004 Air Conditioner
Ac. spits out water in the front and ac., is tilted back ,gets worse as it runs
You need to blow into the drainpipe on the outside of the building to clear the blocked drainpan outlet. This just to make sure that your drain is clear. If the problem persists. Check that the filter is clean. This can also happen if you are slightly short of refrigerant and running the aircon at 18C or lower on a humid day.
Apr 28, 2009 | Heating & Cooling
Airconditioner doesn't cool
If the fans and the compressor is running your low on refrigerant
Oct 06, 2008 | Dometic Rooftop RV Air Conditioner
Airconditioner is on all the time now, but frosty ice is forming on the coils. The air coming out then becomes cool, but not cold and then we have to turn it on to fan in order for the ice to defrost...as...
most airconditioners will have a cutout or something called a defrost cycle, which turns it off for a while to let the ice melt. And if you run it flat out all the time this may happen too (happened to me in Thailand once, so I just turned it on when I was in my room - and it worked much better)
If it has just started doing it, the recycle timer may need repairing
Jul 10, 2008 | Heating & Cooling
Leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Sep 04, 2007 | Friedrich QuietMaster RS10J10 Air...
Heating & Cooling Logo
134 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
