Question about E-Machines eMachines Desktop PC
The cd player won
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
Here is an easy fix to open your CD player all you need is a small paper clip. Open the paper clip up so its a straight wire. Make sure your computer is not on it needs to be turned off to do this. Look at the front of the CD player you will see a small pin hole opening. Push the straight end of the paper clip in that opening (hole) and push. Your drawer for your CD player should move forward enough for you to pull it open all the way. Once you remove the CD that is causing it to jam you should be ok again.
I hope this helps out if so please leave me some feed back.
Posted on Apr 02, 2011
CD player won't open or power off.
The CD may be stuck inside or the tray mechanism may have failed
Dec 08, 2012 | Audio Players & Recorders
Cd player won't open and won't power off.
This means that something in the mechanism is jammed. It keeps on trying to correct for the misalignment- a service technician will need to see the unit.
Dec 08, 2012 | JVC XL-FZ258BK 5-Disc CD Changer
CD Player Won't open
There are a few reasons, a broken loading belt, jammed gears, or the timing is out of sync causing the system to lock up.
Mar 20, 2012 | Panasonic SCPM29 5-Disc CD Changer
Two cd in same slot won't eject
Try disconnecting the CD player from power,press and hold the open button and the connect and turn player on.Release button after it indicates open on the on player.Tap the top part of the player with your palm while pressing open button.
Hope this helps.Thanks!
Oct 16, 2011 | Audio Players & Recorders
The CD won't spin
there are lens cleaner cds with liquid cleaner. get that kit & run this cd with cleaner on its brushes. if still not working unplug the system & open the cover & see there is lens on cd drive unit. clean upper surface gently with soft cloth. if not working then replace the cd drive mechanism.
Aug 25, 2011 | Bose & Wave& Music System
I have a Phillips model 601/25 CD player and the CD drawer won't open - it makes a whirring noise but refuses to open.\r\n J A Adamson <jadamson35@gmail.com>
The rubber band has stretched with age. Easy fix, take cover off (several screws around the case) and band is easily accessed. Even a cheap elastic band will work as a replacement for now, it only opens the drawer mechanism, no effect on sound quality.
Aug 20, 2011 | Philips Audio Players & Recorders
I have a sharp cd-sx62v player it displays me protect message as i switched on the power and no other buttons are working so i am not able to play cds, cassete, fm.please help me
Reset the player by pressing ON/STAND BY button and simulatenously press preset << and preset>> buttons of the unit.
This will reset the microprocessor of the player.
Aug 09, 2010 | Sharp Audio Players & Recorders
CD player WILL NOT PLAY and does not recognize CD presence
HI. this is optical lens assembly failuer. the optical lens is burned out, in return, inducing the (no CD) message. simply replacing the optical lens assembly will fix this issue.
May 27, 2009 | Tascam CD-A500 CD Player
E-Machines eMachines Desktop PC Logo
116 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
