Question about Magic Chef 9122 Gas Single Oven
The ignitors or not glowing oven doesn't come on at all what can i do
  • Magic Chef Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Apr 02, 2011
Whirlpool gas oven will not heat
most likely you have a bad ignitor,pull out the racks and remove the floor to the stove,turn on the bake,if the ignitor glows but it takes more than 40 seconds for the flame to light you have a bad ignitor even though it glows and if it doesn't glow at all the ignitor is bad,also if the broil lights on top and the bake doesn't change out the ignitor.next time send the model number and i can look up your machine to help you better.
Nov 15, 2011 | Whirlpool Ovens
I have a magic chef ovan/mic unit, when I press the bake option and set the temp the igniter goes on but the gas does not kick in. model # 54FN-5TKVWM
even though the ignitor glows it doesn't mean it's good it opens the gas valve by amps not just because it glows,if you turn on the stove and when you see it glow if the flame doesn't ignite within 40 to 50 seconds you have a bad ignitor.if you leave it alone for a few minutes does the flame ignite?the only other thing it could be is a bad gas valve but most likely it will be the ignitor
Sep 25, 2011 | Magic Chef Ovens
Oven doesn't light. The element glows, but the
Hello Randolph,
Since the ignitor glows it eliminates all other possibilites and the ignitor is weak and not drawing enough amprage(3.3 to 3.6) to open the gas valve, i know you going to have a hard time believing that since it does come on, but i base my diagnosis on my 30 years experience as a appliance repair technician
Gene
Jul 25, 2011 | Kenmore Ovens
I have an Amana ARG7102W P1143347NW gas range that the oven will not light. All other functions work including the broiler and the oven ignitor glows brightly. I don't think it is getting gas to the...
most likely it will be the ignitor,even though it glows it doesn't mean the ignitor is good.it works on amps.a flat ignitor takes 3.2 amps to open the gas valve and a round ignitor takes 2.5 amps to open the valve,the only way to check it is to replace it and i would or if you have an amp meter with a clamp on it you just stick one of the wires going to the ignitor inside the clamp and it will tell you how many amps are coming out of the ignitor.buy a new ignitor and you should be fine.it calls for ignitor part number 31940001 and it's around 50 dollars.
Jun 12, 2011 | Amana Ovens
Broiler won`t lite.i replaced the ignitor but it doesn`t glow at all.sounds like an electrical problem
heatman101
May 11, 2011 | Ovens
Hoping someone can point me in the right direction. Oven won't light, but the stove top burners are fine. Don't smell any gas or any indication the oven is attempting to light....
next time send the brand name and model number so i can look up your machine,if it's a gas stove most likely it will be a bad ignitor,even if the ignitor glows it still could be bad,if the flame doesn't ignite and the ignitor is glowing change it out,if it isn't glowing pull out the ignitor and check it with a meter,common problem.
May 07, 2011 | Ovens
STOVE WORKS BUT OVEN WILL NOT HEAT UP - GAS OVEN
There are 2 high likelihoods as to what your problem may be. When you turn your oven on, does the ignitor begin to glow within 15 to 30 seconds? If it doesn't, there is no power going to the ignitor and the control mechanism is going to need to be replaced. If you have a manual dial thermostat control, you can order this on-line at parstdirect.com. If you control is electronic, you will be required to have an appliance technician come out in order to send the old controller in to be rebuilt.
If your ignitor is glowing when you turn on your oven, but it has a very dull orange glow, you have a bad ignitor and it needs to be replaced. This is the most common problem with older gas ovens. The ignitors just burn out after time and do not draw the amperage needed to open the safety valve.
Replacing the ignitor is a fairly easy procedure. Replacing a dial thermostat control can be a little rough due to rerouting the thermocoupler back through the oven body. Unfortunately, the electronic style oven controls can only be sent in for rebuilding and the company that you use will need to be able to handle "Retforrepr Rebuilds".
May 01, 2011 | Magic Chef 9122 Gas Single Oven
Hello and thank you for your help. My lower oven will not ignite while the smaller upper oven will. ?????? Thank you Rob
most likely all you have is a bad ignitor.if it glows it should ignite the flame in less than 40 seconds,if it doesn't glow,pull it out and read it out with a meter.next time send the model number.good luck.
Apr 30, 2011 | Maytag Ovens
My oven works fine it just doesn't heat-up. I can hear ignition clicking but no fire from burners. A technican told me to purge the union above gas to get rid of air in the line. Thanks Louis
Personally I wouldn't describe an oven that doesn't heat up as working fine. You shouldn't have any air in your gas line unless this is the first time firing the oven, in either case the air in the gas line would work its way out eventually and the oven would light on its own.
Check to see if your ignitor is glowing before you hear the clicking, if the ignitor isn't glowing it needs to be replaced and is fairly easy to do so. If your ignitor is glowing you should check to make sure you are getting gas to the burner. The only way I would recommend checking this is with your nose, do you smell gas when the gas valve clicks? If you do then something is wrong with the burner, either dirty or the exhaust is too strong, or even gas pressure too low. If you don't smell any gas that doesn't necessarily mean no gas is coming out, at this point you should call a authorized service provider to take it over from here.
Nov 03, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Older Maytag built in oven. starts and reaches desired temp, sometimes. Other times it never lites. electric igniter always reaches a glow
Even if the igniter glows... that doesn"t mean the ignitor is good. The igniter is wired in series with the oven bi-metal valve. Many times the ignitor will not allow the correct current to the oven valve for it to open... even though it is glowing. I would recommend replacing the ignitor first, you should be able to find one for under 40 dollars.
Aug 10, 2010 | Maytag Ovens
Magic Chef 9122 Gas Single Oven Logo
79 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal De GO PATS
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
