Question about Ricoh Aficio SP-C210SF Printer
NOISE my ricoh sp c210sf makes a loud grinding noise when retrieving a sheet of paper from the tray to print.
  • klguthrie Oct 29, 2008
    It does not seem to stop the machine from printing. I thought it was just loud.
  • anytimechris Dec 26, 2008
    I have the same problem. Is $399 the cheapest solution? Is there anything I can do myself to fix it?
My machine had the same problem. A service tech looked at my machine and pulled out the OPC Belt Drum Unit. The drum unit had a few issues: 1) jagged rips in it, something caused by running papers through that had staples or paperclips in them. So when the drum turns, it scrapes other parts and the machine sounds like its going to drop all its nuts and bolts--at least mine did!)! and 2) the spindles from the OPC unit has come loosened and fell off. The spindles and plastic cogs were found way at the bottom of the OPC Drum slot. This too was thought to have added to the rips in the drum.
I replaced the drum ($399 was the cheapest I could find) and the problem went away.
An expensive repair but for me it worked...
Posted on Oct 30, 2008
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
My company has a Ricoh Aficio SP4310N printer and it will not pick up or feed the paper in the tray. The rollers have been cleaned. The printer makes a grinding noise when it tries to print. Then i
when printer cant pickup paper may be shown this massage .check pickup roll.it may be scoured.raplace it .BUT if when you make power on comes masage check sensores. specially exit sensor.
Oct 06, 2017 | Ricoh Aficio SP 4310N Laser Printer -...
Why is ricoh 6330n making a loud noise while it is printing?
Check the transfer roller (the sponge roller) there will be a gear on that roller. Lubricate is with some spray on lube.
Aug 11, 2014 | Ricoh SP 6330N AllInOne Laser Printer
Continuous jam paper feed cl3500n
I THINK THE NUMBERS BUTTON HAD PROBLEM, TRY TO CHANGE THE NUMBERS BOARD & SEE IF THE PATTERN STILL PERSIST. IF THE PATTERN PERSIST ALTHOUGH YOU INSERTED NEW NUMBER BOARD, THEN YOU HAS TO GO IN SP MODE TO CHANGE PRINT SETTING
Sep 26, 2013 | Ricoh Aficio SP-C210SF Printer
Paper jam c
Unable to print troubleshooting and routine maintanance chapter in user's guide
Mar 23, 2013 | Ricoh Aficio SP-C210SF Printer
Ricoh SP C410 DN jam from bypass
If you can take off the bypass unit, two screws and a harness, you may be able to check the shaft, bushings and rollers. Sometimes removing jammed paper cause parts to get out of normal position. The grinding noise for example, gears not meshing together correctly. If it worked before the jam, then that is where I would look.
Apr 20, 2017 | Ricoh Aficio SP C410DN Laser Printer
Xerox 6360dn, Tray 2 makes loud grinding noise when printing. Tray 1 is as quiet as a mouse. Replaced tray 2 with a known good tray and it still makes grinding noise.
In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
Oct 18, 2010 | Xerox Phaser 6360DN Printer
My Ricoh Aficio SP-C210SF Printer jams almost every other print i make. What should I do?
is the machine new?
check the paper size, check the paper tray -if the paper end fence is loose(the paper should not move around).
try using fresh paper(from a sealed pack)
Jan 07, 2010 | Ricoh Aficio SP-C210SF Printer
Ricoh C21SF Automatic Document Feeder (ADF)
Take a little soap and a little water and clean the gray feed tire that is located in the document feeder. Check for any paper obstructions. If the machine has had a lot of prints I would replace the feed tire.
http://www.websitetoolbox.com/mb/copierquestions
Sep 25, 2008 | Ricoh Aficio SP-C210SF Printer
Ricoh Aficio SP-C210SF Printer Logo
738 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
