Question about Mtd Garden
Have difficulty removing mower blades. find it impossible to remove the nut. is it left or right hand thread ?
  • 43,501 Answers
The threads are right hand....
wedge a block of wood into the blade to hold it
then you can really push on the nut...
also make sure you have a good fitting socket wrench
add a pipe on the handle for more leverage...
you also can heat the nut to red hot and then let it cool
which will also help to loosen it...
heatman101
Posted on Apr 02, 2011
What direction to turn nut to remove blade from an HU625AWD LAWN MOWER
normal right hand thread so counter clockwise to undo
Apr 30, 2017 | Garden
What would cause my walker zero turn mower right blade to fall off of become loose after tightening the nut about every 5 minutes while mowing?
check to see if that side is supposed to have a left hand nut on the correct spindle
are you using the dish shaped washer under the nut
are you using a spring washer or nyloc nut
Mar 28, 2016 | Garden
Murfield lawn mower blade removal
usually right hand bolts
Jun 26, 2015 | Garden
HOW DO I REMOVE THE BLADES
The blades are typically a 'right hand' thread and tighten against the normal blade rotation for safety reasons. This means they have a tendency to work themselves tighter during use. Try using a good pair of LEATHER gloves and hold the blade with one hand while loosening the bolt (or nut) with the other. To loosen, turn the bolt (nut) COUNTERclockwise.
If this is a push mower... REMOVE THE WIRE FROM THE SPARKPLUG FIRST !!!!!! Push mowers can start when rotating the blade by hand because it turns the engine over just as a crank or pullrope would.
Make sure to take note of the positioning of the cutting surfaces of the blade and re-install them correctly...many mowers have had their blades installed backwards by mistake.
Take extra care when re installing them as they will now be SHARP !!!!!
Mar 08, 2015 | Garden
Replace blades on Mtd mower deck
no they are not left hand threads if nuts have molded washers you must use an impact gun. wash holds too much of blade surface and will not turn against it
Jul 17, 2010 | Yard Machines 155 Torque Briggs Stratton...
Are the nuts holding on the blades reverse threaded?
If a blade, when viewed from above, rotates clockwise, it will have right-handed threads. This is because the shaft is turning to the right, and the resistance imparted on the blade will tend to tighten a right-handed fastener. If a blade rotates counter-clockwise it will have a left-handed fastener. I don't know this mower, but this is a universal thing.
Apr 23, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
CUB CADET ZERO TURN Z-FORCE 3-BLADE CONFIGURATION
Under each blade is one single nut holding each blade on. It is not left-hand thread and there is nothing special about it.
Standard thread - Standard hardware - Standard tools. (If memory serves, you need a 15/16" socket to remove these.)
There is no need to index or time the blades. They cannot hit together unless something is bent or damaged on your mower deck.
Hope this helps,
Dolf-
Oct 14, 2009 | Garden
I cant get the nuts off the blades on my cub cadet do you turn them l or r
Not sure on your particular mower but most all mowers are left hand threads so you would loosen like you are tightening normally. I hope that is clear to you. lol
Sep 11, 2009 | Classic Accessories Garden
Garden Logo
177 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
