Question about Samson Auro D412A Speaker PA Active
What do I need to hook up to our church pa system
  • Samson Master
  • 5,603 Answers
Connection all depends on what type PA system you have. Here are the rules: Power this device from the SAME receptacle your mixer is powered by, even if it means running an extension cord. Use ONLY a balanced line from the mixer... either TRS cable or XLR cable.
Posted on Apr 03, 2011
Is there a way to hook a Mackie profx12 mixer to "this" Peavey PA?
We would need to know which Peavey PA you're asking about.
Feb 18, 2016 | Peavey Music
How do I plug mixer into pa speakers, monitors, instruments
Without knowing what make and model of the gear you're looking to connect, I can't give you a definitive answer. However, in general, if you have a powered PA mixer, meaning it has both a mixer section and a power amp section in a single box, the main speaker outputs will be on the rear panel of the box and marked as such. There will also be a jack for monitors, but some mixers have an amp for monitors, some just have an output for the monitor mix, but not an amp for them, and on some you can switch the main outputs to feed either a Left and a Right speaker, or a front mono speaker and a montior speaker. Instruments will go into the individual channel inputs.
Feb 08, 2015 | Music
Problem is after a few minutes i lose all sond comming from my speakers
Not likely a grounding problem. Run a test: Turn on unit with NO sound into the mics and wait 5 minutes... now try the mics. If they start working for a few minutes, then the amp is being overdriven. These small systems can be overheated and a thermal protector shuts them down to protect them. A hidden problem is if the mics are in front of the speakers you MIGHT have ultrasonic (above hearing range) feedback that may be overheating the unit. Put your speakers nearer the audience and mics behind. If problem persists, exercise your warranty.
Oct 21, 2012 | Harbinger HA120 Portable PA System
Can I hook up a monitor to a Harbinger HA120 Portable PA System
Yes you can,you will need 2 run ,1\4 in 2 jack 1\4 in imput too the mic\line imput your chaing your signal so you will need too preset vol levels on the 120 too your desired max peak out put buy first putting you output slide too max on your mixer (running a signal from a cd player or other divice into mixer)then turn vol up 2 disered max loudness you want to run sound at then lower the vol using out put from main power slide on your mixer. Its called chaining your componets .better way of hooking up a band on a small system.ywc Rev bob dj 25yrs exp
Sep 06, 2012 | Harbinger HA120 Portable PA System
Could you use the Bose 901 series VI for a pa system?
Actually that's where the bose 800 systems came from.
Old school jazz guys were using their 900 series turned backwards as a pa
Mar 31, 2017 | Music
We do not understand how to project a DVD movie. Do we only hook up the projector or do we hook up the computer and projector?
Depends where the "source" is. If you want to show your pictures and videos that are on your computer. Or play a dvd from your pc, then yes you need to set up the computer
Nov 04, 2011 | Hamilton Electronics Hamilton Venu100...
Using Boss FV 50H between output of Tascam M-216 mixer and church PA (line input of main mixer) with microphones on 1 channel and guitars on other. Problem:Quite a loud "pop" or...
The problem is you have an ILLEGAL connection based on proper electronic design. This pedal has UNBALANCED high impedance interconnects and the output of your mixer and the PA SHOULD be BALANCED low impedance interconnects. This makes the system subject to noise and you may even get static discharge noise. Also verify that the TASCAM and the PA system are ALL powered from the SAME receptacle or power conditioning module. This is a tough design problem to achieve what you want. Essentially you want to make the master gain of the TASCAM on a foot pedal as I understand it. There is one pedal that CLAIMS to have balanced in and out and if I had the schematic I could verify it... but I could not find the schematic in my searches... look at: http://www.sweetwater.com/store/detail/StealthPedal
This one MIGHT do the job right. You MUST use TRS BALANCED cables, NOT TS, from the mixer to this and from this to the PA. Do research on BALANCED and UNBALANCED and TRS and TS and also XLR cables using google to understand the difference and importance of using balanced interconnections in your system. I would try to get one of these pedals on approval with the correct cables and test it.
Sep 18, 2011 | Roland Boss Fv-50h Stereo Volume Pedal...
When plugged into my churches pa system through a direct box the volume gets really loud then really quite and then sometimes normal. I'm using a lithium battery
Talk to your sound man... It is possible he has a compressor on the line. A compressor adjusts the volume dynamically and delays tweeking and releasing as a setting. Your guitar should NOT run through a compressor.
Aug 08, 2011 | Martin Guitars Martin XC1T Ellipse...
Hook up extra speakers
Most of these portable PA systems do NOT have amplifiers capable of driving extra speakers SAFELY without risk to the amp.
I would NOT attempt to drive more speakers without using another amp to drive those speakers.
Sep 19, 2010 | Peavey 00511800 Escort Portable Sound...
Popping sound through sound system speakers
make sure that the trim (gain) isnt set too high on your keyboard's PA channel. it might just be clipping due to input levels that are too hot.
Nov 24, 2008 | Yamaha Music
Samson Auro D412A Speaker PA Active Logo
252 people viewed this question
Top Samson Music Experts
Michial Gueffroy
Vito Vacirca Jr.
PBandJ
PBandJ
Level 1 Expert
Are you a Samson Music Expert? Answer questions, earn points and help others
