Question about Polaroid T831 Digital Camera
My polaroid t831 turns on then immediatly turns off, and the lens are stuck they won't go back in
    Guru:
  • 441 Answers
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Posted on Apr 10, 2011
It will not turn on and it flashes a orange light
This is most likely a power problem, but could also be a stuck lens. Here's a couple of website that explain what you can try to get it working:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
and:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
A stuck camera lens can cause this problem, also, but it's usually a power problem. Make sure your battery is fully charged, and the battery and camera terminals are clean (clean with a qtip and at least 90% isopropyl alcohol).
Good luck, and hope this helps.
Oct 15, 2010 | Polaroid T831 Digital Camera
Plug in polaroid t831 to pc and pc doesn't recognise that it is there
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
May 20, 2010 | Polaroid T831 Digital Camera
When I zoom in, the camera shuts off
Stephan, I had the same problem as this user did, I tried to zoom and it would shut off, what I did was one of your options, zoom and as I did turn the lens, like help it zoom. Now it works, thank you so much for your help! :) I thought my camera was doomed forever!
Nov 14, 2009 | Polaroid T831 Digital Camera
I need to download my Polaroid t831 driver
You don't need a driver. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Oct 29, 2009 | Polaroid T831 Digital Camera
Need user manual for Polaroid t831 camera. Model: CTA-00831H
Please follow the below link to download the manual.
http://safemanuals.com/user-guide-instructions-owner-manual/POLAROID/T831-_E
Sep 09, 2009 | Polaroid T831 Digital Camera
My camara won;t turn on everytime i get a orange light then it turns off completly
charge the battery until light changes from red to green, then when you put the battery back into the camera make sure you push the battery all the way down until it locks in place. Hope this helps
Aug 16, 2009 | Polaroid T831 Digital Camera
My lens is stuck!
Sometimes this can happen if the battery cover was accidentally opened while the lens was moving. Try something simple. Turn the camera off. Open the battery cover and remove the batteries for 5 minutes. replace the batteries and secure the cover. Turn on the camera. The lens should go to it's home position. Let me know if this helps. And thanks for coming to FixYa. Don't forget to rate my answer!
Rob
Feb 08, 2009 | Polaroid T831 Digital Camera
Polaroid T831 Digital Camera Logo
76 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
