Question about Amcor Aire UCHW-H09AF2 Split System Air Conditioner
I am getting an E7 error message with a little green man on my inside fan set
  • 73 Answers
E-7 code = Defrost cable not connected.
Support@Pridiom.com
201-266-8234 option 2
Posted on Sep 02, 2011
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems
Jul 29, 2016 | Sharp Ar 5316
E7 message
A/C Blowing circuit breaker and giving a error code E7 - Heartland ...
https://www.heartlandowners.org/.../24381-A-C-Blowing-circuit-breaker...
May 21, 2011 - 10 posts - ‎4 authors
Has anyone have any idea what could cause this issue? It is a Dometic rear AC with HP and will not cool at all. The fan runs but no cooling at ... Dometic Refrigerator - Error code E-3 - On the road, help ...
Jun 6, 2015
Dometic CCC 2 Error Code E7
Aug 9, 2014
Dometic A/C won't turn on with remote or from unit
Aug 30, 2012
More results from www.heartlandowners.org
Dec 02, 2015 | Heating & Cooling
I am getting an E7 error code on two new AM 04 heater fans what does it mean
E7 error was an engineering code from an old batch of fans and that they had since fixed the problem.sell the old batch
Nov 09, 2014 | Dyson Hot Heater Fan AM04 - Blue
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
Mar 23, 2014 | Singer 7258 Sewing Machine
Pioneer Plasma Tv Throwing Code (11 green blinks on front lights) also on Screen Says (Thermal Alert Shut Down (11) )
Possible set is seeing a temperature too hot inside the set, can also be a fan in the unit if it has them it takes very little dust to slow their speed enough (dust on the fan blades).
Dec 22, 2012 | Televison & Video
My Nokia E7 phone's charging but not conected on PC,what can i do.
BEFORE PLUGGING UP TO COMPUTER
menu -> settings -> wireless and networks -> USB utilites -> connect storage to PC (click this button) -> it'll give you a message "Connect USB cable to use mass storage" ... connect the usb cable -> the android man will pop up w/ a msg saying "Phone connected to computer via USB. Tap the button below to copy files between computer and Android's USB storage" theres a button below that says "connect USB storage" (click on this).
your all set
Dec 13, 2012 | Nokia E7 (16 GB) Smartphone
My error message is E 7 flashing. After leaving it off over night it worked for a couple of copies. Now I am getting the same error message E7.
press and hold the copy key the second part of the code will show then go to google and type in "sharp ar-m205 E7-xx"
where xx is the last of the code you should get an answer there
Jan 12, 2010 | Sharp AR-M205 Copier
When scanning, received error message "selected servers are not found. Consult you network administrator." Never received this error before, and as the administrator, I have not changed any settings.
If your network is set up to DHCP your leases may have expired and your server may have given new IP Addresses to the destinations you want to send to. Check in the settings of the MFP (copier) that the IP address matches what the IP Address (check at the computer as well) on the computer is. When all else fails (including reboot of all) reinstall the software.
Oct 27, 2009 | Sharp MX-2700N Color Copier
I have an 18 K unit with E7 error on heat mode
I just installed a YMGI brand mini-split AC and had exactly the same problem. AC worked fine, but when I tried using heat mode I would get an E7 error.
After talking to their tech support I discovered the problem. There was a separate cable that needed to be connected that I'd forgotten to hook up. This cable runs from the internal unit to the outdoor unit and connects a defrost sensor.
In my case I had totally missed that cable when I installed the unit. After running another line and connecting it the unit is now functioning normally.
If this is a new install, then make sure all your cables have been run. If it was previously working, then check to see if one of the cables had become disconnected. If it's not the cable, then it's probably the sensor.
Good luck
Oct 18, 2009 | AmcorAire UCHW-H12AF2 Split System Air...
Amcor Aire UCHW-H09AF2 Split System Air Conditioner Logo
274 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
