Question about Sony Computers & Internet
Sony vaio Desktop Windows XP. Turns on but never actually starts up goes to screen where you can start safe mode, and other choices. None of those work. Took to Best Buy. Tech says Windows corrupted need to restore. I have recovery CD's so figure I will save myself $140 and do it myself. Tried started it with CD in but still goes to that safe mode screen. How do I get it to start on recovery CD. I did the F2 thing someone suggested but don't see anything that says reinstall windows? Andy advice?
  • 61 Answers
Hi the best thing to do...is press and hold delete when the laptop is starting up,and go into the bios,and make sure that the 1st boot device is you cdrom,after you have enabled that to be your 1st boot device then press f10 and enter..then your laptop will reboot...
open up your cdrom,insert your operating system,then press the laptop power button to shut it down then power it back up...then hopefully it will prompt you to make a fresh install..
Hope this help and if there is anything else i could help you with..
Regards
Posted on Apr 03, 2011
Sony vaio all in one touchscreen stopped working
XP and Vista Normal Mode Start your computer as you normally would. Click the "My Computer" icon on your desktop. Go to "C:\ Program Files\Sony\Setting Utility Series." Find and choose the "VCCPointingDevice" folder in the "Setting Utilities Series folder" to open the "Built-in Pointing Device" dialog box. Locate the "Enable" box on the "Built-in Pointing Device" dialog box. Check the box to enable the Vaio touchpad if you wish to use this device. Disable the touchpad if it is interfering with the external mouse. Uncheck the "Enable" box if you have a USB (PS/2) mouse connecting to your Vaio and wish to use that instead of the built-in touchpad. Pick "Yes, I'm Sure" when prompted to activate your choice, then close all the windows. Windows 7 Normal Mode Launch Windows as usual. Go to "Start" > "Control Panel" > "Mouse" > "Pointing Device" to open the Vaio touchpad control center. Uncheck the "Enable" box on the "Pointing Device" window when you wish to use your external mouse. Check the "Enable" box on the "Pointing Device" window when you want to use the Sony Vaio touchpad. Make sure the external mouse is not interfering with the touchpad if you have one connected. If so, unplug the mouse from your computer. Click the "OK" button at the bottom of the "Pointing Device" window. Close all other windows. XP and Vista Safe Mode Restart your computer. Press the F8 key before the Windows welcome screen appears to enter Safe Mode. Click "Start" > "Control Panel" > "Add/Remove Programs." Find and delete all software for mice and pointing devices. Restart your computer in normal Windows mode. Proceed to next step if the problem persists. Restart your computer in Safe Mode. Right click the "My Computer" icon on the desktop. Choose "Properties" on the drop-down list. Pick the "Device Manager" tab in the Properties window. Select the "Other Devices" folder and click on the "+" sign besides it. Delete all the devices under this "+" sign by clicking on the "Remove" button next to each of the items. Restart Windows in Normal Mode. Once Windows is operating, there will be a "New Hardware Wizard" pop-up that will load all the necessary drivers for the touchpad, mouse and other pointing devices. This should fix the corrupt driver for your Vaio touchpad. Windows 7 Safe Mode Reboot your computer and press the F8 key before the Windows welcome screen appears to enter Safe Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Click the touchpad icon. Choose the "Driver" tab and press the "Uninstall" button. Press the "OK" button to confirm. Restart Windows in Normal Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Choose the "Driver" tab and press the "Update" button. Press the "OK" button to fix the touchpad software.
http://esupport.sony.com/perl/swu-list.pl?mdl=PCGFRV26
Feb 08, 2013 | Sony VAIO Computers & Internet
Sony vaio touch screen stopped working
Feb 08, 2013 | Sony VAIO VGC-LV180J 24-Inch All-in-One PC...
My A30 ibm laptop wont start up??
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 03, 2010 | IBM ThinkPad A30 2652 Notebook
Sony vaio not loading windows
reinstall the OS ! Just overrite it over the previouse xp so u won;t lose data ...
..most probably u are missing some files ... .. or u have virusez issues. Ofecourse there is the posibility of hardware mallfunction, but considering microsofts reputation ... probably thats not the issue ...
Dec 10, 2008 | Sony VAIO PCV-V210P PC Desktop
Sony Vaio PCV-RS710G wont start up
one of the files in the system32 directory in the windows folder is corrupt, the files in the system32 folder contains vital files for the boot procedure, try to start the machine in "safe mode" by pressing F8 after the sony boot screen, if it allows you into the operating system you will need to choose "system Restore" take the time back to at least a week before your problems started DO NOT CREATE A RESTORE POINT
Nov 14, 2008 | Sony VAIO PCV-W600G PC Desktop
My computer says windows did not start sucessfully
go to safe mode and create new user account, and try again....
if it doesn't reinstall the OS..
Jul 30, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Will not boot Windows XP
When your computer is rebooting, push the F8 key. It will change your start up options and you will see disable automatic reboot on system failure. You can they see the error and continue research on the problem.
May 05, 2008 | Sony VAIO VGC-RA840G PC Desktop
The system will not load
your operating system is corrupted, you need to reinstall your winxp cd in order to repair the corrupted file. in order to prevent the recurrence of this upgrading from vista you need to turn off or select from the automatic updates selection portion. vista has a higher requirements qhen it comes to its memory, video cards and so on and that is the reason why the update did not pursue which eventually corrupted your operating system.
i'm hoping that this will help you
Dec 18, 2007 | Sony VAIO VGC-RB50 PC Desktop
Locked in windows start mode
it may be mother board problem.but you can try once
start your pc keep on pressing F8 key to get screen you have mentioned . select to boot your system in the safe mode it takes some time to boot it will show (multi disk 0) .once you get enter into the OS, go to programs-- accessories--system tools--system restore and restore your computer in earlier date.
if it again show the blue screen you will have to take the system to the technician try this and let me know
Nov 22, 2007 | Sony VAIO PCV-W510 (PCV-W510G-BDL1) PC...
Computers & Internet Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
