Question about Maytag Dryers
The igniter comes, on the gas comes out and ignites then it shuts off.
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Apr 02, 2011
System wont ignite. chgd filter & batteries in thermostat
Does the igniter get hot? If it does, then there is a problem with the gas control, that is, the gas won't come on for some reason. Generally, the gas won't come on if the igniter fails (for safety reasons), so are you sure there is gas flowing? You would hear the cycle start, that is the lighter, and even air flow, but if the gas doesn't come on during that time, the system shuts down in a few seconds.
Nov 30, 2015 | Heating & Cooling
I have a whirpool cabrio gas dryer that igniter comes on and heats for a short time but won't relight
Bill,
Could you be a little more specific? Does only the igniter come on, but no gas, or does the igniter come on, then gas, then it shuts off?
Oct 15, 2013 | Dryers
I have a Johnson air ease 90 plus.I turn the thermostat up and exhaust blower comes on igniter comes on and i can hear the natural gas release for a second or two then igniter shuts off along with gas. Fan...
If the burners come on for a few seconds and shut off check the flame sensor near the burners and clean it with steel wool, usually this will fix the problem. The flame sensor is a metal rod that is immersed in the burner flame on the opposite side of the igniter. robhvac47_7.jpg
Jan 17, 2011 | Heating & Cooling
No heat..revolves, blows ok...is there a fuse that shuts off gas?
Theres a fuse that shuts off the igniter. It can be the igniter or thermal fuse. If you see the igniter glowing but no gas coming out replace the coils on the gas valve. If that fails replace gas valve
Feb 13, 2010 | Kenmore Dryers
Gas oven won't light on Tappan Centenniel. First, the burners come on, so gas is getting to it. When oven thermistat is turned on, some sort of electric igniter element glows. How does this igniter...
The inside of igniter has a probe that is heated, When it is time to light, the solenoid opens gas valve and allows gas, then that heated probe ignites the flame. After temp is reached fuel is shut off.
Oct 29, 2009 | Kitchen Ranges
Oven doesn't light. I have a Maytag MGR5750. The pre-heat light comes on but no ignition. Stove top burners work okay.
First thing to do is verify if the hot surface igniter or spark igniter is working. If the oven has a bottom broiler compartment then you can check from the bottom compartment. If it has a top broiler then you may need to remove the inner bottom cover inside the oven to look at the burner and igniter. Now turn on the oven and watch for the hot surface igniter to start to glow or the spark igniter to come on. If the igniter comes on then give the gas control valve(located at the bottom broiler/storage compartment) a tap with a wrench or a screwdriver. If the burner comes on then shut the oven back off and on several times COMPLETELY. If it works then you may have fixed the problem by dislodging debris in the valve. If it does not come back on then the gas control valve may be defective or the igniter could be weak. The igniter should be tested with a ohm meter and if it tests good(500-700 ohms usually) then the gas control valve will need to be replaced otherwise the igniter is bad. On spark ignition systems there is a different procedure. Another thing to check is the "runaway valve" that is located on the gas regulator for the range. It is a little lever located where the oven gas pipe comes off the regulator and cuts the gas to the burner when closed.
Oct 16, 2009 | Maytag Kitchen Ranges
Oven wont light
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils(This will be the next possible issue if the igniter is functional)
Sep 26, 2009 | Frigidaire Ovens
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
Dryer ignites but does'nt light
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jul 13, 2009 | Amana NGD7200TW Gas Dryer
Dryers Logo
186 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
