Question about TruTech PLV1615T 15 in. LCD Television
Trutech powersupply, I need an IC
Where can I find parts for Trutech powersupply?, I need an IC or a replacement power supply
  • gperry322 Oct 13, 2008
    i am trying to program a remote and i don't know the three didgit code
  • Don Guerrero Oct 25, 2008
    i am looking for a power supply as well want to fix my self to save some cash i'm pretty handy and willing to try at least.
    Any help on where to find parts is greatly appreicated
    Thanks
    Lo
    Champion:
  • 367 Answers
Open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Posted on Sep 07, 2008
Panasonic tc-p42x5 powersupply no power
No standby power on these sets after a power loss is usually a bad IC at location U203 on the back of the power supply board. It's a Fairchild FAN6755 8-pin surface mount IC... A cheap, easy fix if you have basic soldering skills...
Dec 21, 2012 | Panasonic VIERA Televison & Video
When my unit was set at 120volts...I plugged it into a 250volt circuit ... loud pop ...can it be fixed
Hello, Doing something like that,chances are you blew the powersupply , and hopefully nothing else. You can replace just the powersupply 50 dollars or less, if that doesn't fix it will have have to be serviced.
Aug 10, 2012 | Dell HP-P2507FW Power Supply ** FREE...
IW-P250A3-1 Resistor R60 is blown. What is the value?
NO Electrical power? Them Power Supplies sometimes goes out at the craziest times. Normally if a powersupply is faulty, you just replace it, with another one . The problem comes in, when you need a speciality type of powersupply instead of your good ole stand by ATX form factor. It appears to me, you have a faulty 250 Watt power supply that is design for that system. You say it's IW-P250A3 Power Supply and you want to know the cost of the part replacement? I seen for prices like $30.00 dollars of as high as $117.00 dollars. I would check with your local Tech Store, or check out ebay, also maybe a tech site like directron or newegg for pricing. Good luck on your adventure with replacing the PSU. Hope this help.
Aug 17, 2010 | In Win PowerMan (IW-P2400L1-0)...
NEED POWER SUPPLY FOR TRUTECH PLV16320
What is wrong with your power supply?Please let me know.Thank You very much!
Tyler
May 19, 2009 | TruTech PLV16320 Television
InFocus IN24 powersupply part needed
chances are it's a capacitor, if it went on a power supply. get the power supply back and see if the main capacitor is puffy. you can fet one at almost any electronics store. otherwise, replace the whole power supply.
Nov 12, 2008 | Office Equipment & Supplies
Power supply problem?
Hi ktricks
The problem will definitely be with your powersupply , but before investing in a new one - open up the unit by taking off the top cover and replace the fuse that is on the powersupply - this is 90% of the time the only problem.
If this doesn't work , please supply me with the part number on the part and also with your country you are in and I'll send you the pricing and dealer's contact details.
May 17, 2008 | Sanyo PLC XP41 Multimedia Projector
Powe Supply Problem Compaq
I did some research and the powersupply for that machine is a standard ATX powersupply, so yes just about any off the shelf power supply will fit and work. They may be overkill but that's fine.
HP sells the proper power supply for your machine for $98US as part number 176764-001 . There parts store is at http://h20141.www2.hp.com/hpparts/default.asp?mscssid=CADCEXJ9VLH69MBBGJ8N6SELXQ2C2XP1
Jan 11, 2008 | Compaq 187498-001 Motherboard
JVC TV- MODEL AV-K21T.
it was not necessry to replace so many parts if you go as per proper procedure.please proceed as 1 isolate horizontal output section from power supply & make power supply ok. 2 if it becomes ok check hor osc,driver&h/output section. 3 if it is ok connect power input to hor.section which was isolated. 4 check for loose contact or print. 5 put on tv .
Sep 22, 2007 | Televison & Video
No power to projector
Generally when the globe goes end of life and needs replacing the unit will fail to power up. Try another globe if you have one spare.
Sep 10, 2007 | Compaq iPAQ MP2810 Multimedia Projector
TruTech PLV1615T 15 in. LCD Television Logo
48 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
