Question about Brookstone Camping, Backpacking & Hiking
My Brookstone Astro Super Lite has stopped working. Is it the Led or the battery? What is the order of replacing the two batteries? Is the Led unit available for purchase?
2 Suggested Answers
CarlGlas
  • 283 Answers
SOURCE: Where can I purchase a replacement battery for the
http://www.tempestbatteries.com/html/tr6-6.html
Posted on Nov 02, 2010
Need a replacement battery cover for brookstone grill light
Fixya does not sell replacement battery covers for Brookstone grill lights.
Oct 16, 2017 | Brookstone Grilling
Why does my light not charging
Lithium ION batteries are ususally rechargeable. The use mode for these batteries is that there
are a set number of recharges that equate to the life of the battery. Usually that life is
approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the
battery is used up, the maximum charge lessens which means where you may have had 8
hours of play time when the battery was new, you will only have 6 hours as the battery life is
used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge
left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never
recharge again or the max charge will be reduced to an insignificant amount of the original full
charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries
cannot have their batteries replaced.
Jun 05, 2014 | American DJ megapixel led high powered led...
I have a Nintendo DS Lite that will not charge. The orange LED does not come on at all and after leaving connected for 12 hours, the battery is not charged, red LED comes on after a second or two. I have...
it sounds like it's a battery problem.
If you want to replace your battery, call Nintendo's Consumer Assistance Hotline at 1-800-255-3700 from 6 a.m. to 7 a.m. Pacific Time, and order a replacement battery there. I believe it costs around US$15.00.
If you still need assistance I would suggest you check our online troubleshooting here. Depending on the specifics of your situation, the problem may be the DS Lite, the battery, or the AC adapter.
PCHELPSTER007 from youtube
p.s. Before doing this you could maybe try using a different charger
Aug 29, 2011 | Nintendo DS Lite Console
My Voodoo Lab Super Fuzz stop working. The led doesnt light, and the effect sound doesnt work, but the bypass signal is unaffected... I opened it, and test the resistences they seem to be OK... I don't...
If you are using battery, replace it. If you are not using battery, check your pqwer adapter. Internally, the pwer connectors and soldering around it are chronic problem,
Feb 19, 2011 | Voodoo Lab Super Fuzz Guitar Pedal...
Only one side of the outlets work...
From the User Manual:
“OVERLOAD/CHECK BATTERY” LED: this red LED lights continuously after a self-test to
indicate the capacity of the battery-supported outlets has been exceeded. To clear the overload, unplug some of your equipment from the battery-supported outlets; then use the ON/OFF/TEST button to run a Self-Test. If the UPS continues to detect an overload, remove more equipment and repeat the self test until successful.
CAUTION! Any overload that is not corrected by the user immediately following a self-test may cause the UPS to shut down and cease supplying output power in the event of a blackout or brownout.
The LED flashes to indicate the battery needs to be recharged or replaced. If the LED flashes (and a continuous alarm sounds) during a prolonged blackout or brownout, the UPS’s batteries are nearly out of power; you should save files and shut down your equipment immediately.
If the LED flashes following a UPS self-test (after the UPS is turned ON), it may indicate that the battery needs to be replaced. Allow the UPS to recharge continuously for 12 hours; then use the ON/OFF/TEST button to run a Self Test.
If the LED continues to flash, contact Tripp Lite for service. Should your UPS require battery replacement, visit Tripp Lite on the web at www.tripplite.com/support/battery/index.cfm to locate the specific replacement battery for your UPS.
Hope this helps!
Jul 25, 2010 | Tripp Lite Internet Office INTERNET550U...
Ds lite suddenly stopped working
The orange light goes off when the battery has been charged to its highest capacity. After every charge, the batteries capacity is decreased. Get a new battery, that should do it.
Feb 28, 2009 | Nintendo DS Lite Console
Need a battery replacement battery for cordless theraspa turbo.
Has anyone been able to find out if these Brookstone massagers can have the old batteries removed & replaced?
They stopped selling this model a while ago.
Feb 26, 2009 | Brookstone Theraspa Turbo Massager
Brookstone acuvibe soft touch massager
The current unit sold by Brookstone does not have a power cord. The unit is sealed and the battery is not replaceable. Many units eventually quit working when recharging cycle quits. Only solution is to replace the unit or contact Brookstone for their service center. Probably cheaper to replace the unit.
Nov 04, 2008 | Interactive Health Acuvibe Soft Touch...
IBM-OP500 Battery back-up
Have you tried pressing and holding the off\on switch to make sure it toggles to "normal" rather than "charge"?
Oct 23, 2007 | IBM Tripp Lite Internet Office 500...
Camping, Backpacking & Hiking Logo
200 people viewed this question
Top Brookstone Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Brookstone Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
